1997 LX(non-abs) Overheating
Old Jul 17, 2011 | 06:34 PM
cavrdave's Avatar
Icon2 1997 LX(non-abs) Overheating
The car is heating up to about 3/4 on the temp gauge.
It blew the upper radiator hose about 9 months ago. Since then it started acting up. I have replaced four sensors/switches(ECT SWITCH A and B, ECT SENSOR and ECT Gauge Sending Unit) plus the fan relay. After this it continued heating up. The radiator heated up so bad it melted around the cap and part of the reservoir melted too. Replaced the radiator, cap, reservoir and all of its parts.
The fans seem to function the way they are suppose to. It never heats up to the point of steaming and having to pull over. I have noticed it uses coolant and if you add coolant it runs good. But a couple of days later it is low and starts to heat up again.
Old Jul 17, 2011 | 07:10 PM
HonBeer's Avatar
Default Re: 1997 LX(non-abs) Overheating
Try replacing replacing the thermostat with a stock temp unit.
Old Jul 17, 2011 | 08:37 PM
75aces's Avatar
Did you do the work yourself? Have you tried to bleed the system? The bleeder valve is located next to the thermostat. You might have air in the cooling system. You will need to top off the radiator and open the valve while it's running. Look for the bubbles to minimize from the filler neck of the radiator. Good luck.
Old Jul 18, 2011 | 08:20 AM
cavrdave's Avatar
Yeah, should of mentioned this. I also replaced the thermostat, added coolant of course when I replaced the radiator and bleed the system according to the Honda service manual. Here's an idea...
What about taking out the thermostat and seeing if the problem still exists. If it does then would that point in the direction of a water pump not quite working the way it should? It has 160k mi on it and was thinking about replacing the timing belt and H20 pump.
Old Jul 18, 2011 | 06:24 PM
poorman212's Avatar
Wow...that is like two in three months...very good.
Old Jul 18, 2011 | 06:43 PM
sublime423's Avatar
If I was a betting man I would say you have a blown head gasket.
jald3rd
May 24, 2016 12:11 PM
Freeclowns
11
Apr 14, 2012 04:36 PM
drshottest718
Sep 3, 2009 10:29 AM
spock_rocker
Jun 6, 2005 03:32 PM
