obd2a manual to auto ecu can it be done?
Old Jul 17, 2011 | 02:33 PM
wishingiam's Avatar
Default obd2a manual to auto ecu can it be done?
Is it possible to convert a 5spd ecu to run an automatic? If yes how?
Thanks
Old Jul 17, 2011 | 04:02 PM
HAMOTORSPORTS's Avatar
Default Re: obd2a manual to auto ecu can it be done?
Yes, but extremely involved and not worth it. Just purchase an auto ECU.
Old Jul 17, 2011 | 06:27 PM
NotAJDMFanBoy's Avatar
You'd be better off finding someone to trade ECUs with. I'm sure someone will be up for that.
Old Jul 17, 2011 | 06:36 PM
wishingiam's Avatar
Searching around but nothing local. Didnt think it'd be this hard to find a stock obd2a ecu. Guess I'll keep searching.
HAMOTORSPORTS, What would I need to convert it? I've done an auto to 5spd before, but never did I think I'd ever be trying the oppposite.
Old Jul 17, 2011 | 08:51 PM
You'd have to switch out components to allow the ecu to control the automatic transmission including at least one high side switch like what's used for actuating VTEC. I know that's not very detailed, but I know there's gotta be something on eBay or something. If you could switch to OBD1, maybe run a OBD1 automatic? Or what kind of ECU do you need?
Old Jul 17, 2011 | 09:46 PM
itsnotfast's Avatar
He needs an automatic P2P.
Old Jul 17, 2011 | 10:39 PM
On obd2 ECU's its not as simple to convert as with OBD1. Even with OBD1 switching FROM manual TO auto is quite involved. Also, you shouldn't try switching to an auto OBD1 ECU along with conversion harness as the OBD2 transmissions electronics aren't compatable with the OBD1 ECU. Just get an auto ECU that belongs with your engine/transmission.
beenba
Engine Management and Tuning
Feb 3, 2018 07:00 AM
slowDB7
Apr 25, 2013 07:59 AM
highrev98civic
10
May 13, 2008 02:51 PM
99ekb18b
May 29, 2007 06:41 AM
