D16 Race motor, D2b setup, DSS axels and more!
Race Motor Specs:
D16A6 block
Darton Sleeved
75.5 SRP Z6 pistons (9:1)
H Beam Rods
OEM HOnda bearings
NEW OEM Honda pump
NEW OEM Honda timing belt
NEW OEM y8 Honda HG
ARP Headstuds/Rod bolts
NEW OEM timing tensioner
D16Z6 Ported head
Crower springs
Crower retainers
Supertech valves
GO-AUTOWORKS Camshaft by Web
AEM cam gear NEW
Port matched STR Intake manifold
AEM fuel rail
68mm Throttle body (3" vband outlet)
GO-AUTOWORKS thermal intake gasket
GO-AUTOWORKS -12AN rear block fitting
Vented valve cover
Moroso oil pan
Z6 distirbutor, waterneck adaptor, alternator all included
$3500
Notes: Motor is 100% fine. I just swapped the pump, timing belt and HG when I put it in the new chassis since it was out of the car. This is the complete motor top to bottom.
D2b Kit:
New, fit to the car, started up and run on jackstands, shifting through all gears. Everything fits and works.
Speedfactory D2B kit w/ bracket for EK chassis
Competition Clutch D2B twindisk clutch and flywheel
B series starter
B Series half shaft
$1500
Transmission:
99-00 B16 Hydro transmission
Fresh rebuild, new OEM synchros and gaskets. Installed, started and run through the gears on stands, everything is 100% mint, no leaks, grinds, hickups or whatever. One hole was enlarged for the D2B, but still works fine on B Series setups
-Liberty 5th gear lockout is installed and solid diff.
$800
-DSS 2.9 B Series axles
New, installed, never driven on
$700
Will bundle motor, d2b, and axles together to save $
lol..that shifter fork is new from Honda as well as the upper trans bracket.
Prices are + shipping, pickup preferre3d or will drive to meet within reasonable distance
MORE WIll be added (hondata, turbo kit etc), but the motor must be sold first
D16A6 block
Darton Sleeved
H Beam Rods
OEM HOnda bearings
NEW OEM Honda pump
NEW OEM y8 Honda HG
D16Z6 Ported head
Crower springs
Crower retainers
Supertech valves
AEM cam gear NEW
AEM fuel rail
Vented valve cover
Moroso oil pan
$3500
D2b Kit:
B series starter
B Series half shaft
$1500
Transmission:
$800
$700
Thanks, yes the motor itself has served me well. We have made multiple 10.8-10.9 passes at 135-136mph (1.8-1.9 60ft)with it on a hurt (then broken) D series trans.
Autoworks
Jul 22, 2011 12:24 PM
jDMJeRk
Aug 16, 2009 02:07 PM
