Hearing Noises on my rsx. help !
Okay im running koni's with pro-kit and front & rear spc camber kit. and already got my car aligned , all bolts are firm tight.
First problem is when the car is parked i and i move the steering wheel to the right i hear a " cluck " noise coming from the front passenger side.
When i go up my driveway sometimes a little faster then usually i hear a "pop" noise from under the car.
when i take fast left turns i hear another strange noise on the front passenger side like if it was rubbing on something.
and when i do hit some potholes on the rear it feels like the top hats arent tighten like if something in the back was loose. but i checked everything and it is firm ..
Anyone know what is wrong. or recommend anything that i should replace or should do ?
i already checked all the bolts and they are all firm tight.
first thought would be that the springs aren't seated correctly on your konis. i would double check this, could be what the clunk or pop sound is. just know that you might need an alignment again after taking it back apart
PhuCDatBiCh
Jun 25, 2008 10:57 AM
