ek/ls swap has bogging problem
Old Jul 16, 2011 | 05:29 PM
jdmdreamz414's Avatar
Icon2 ek/ls swap has bogging problem
ok i have a ek with an ls swap..it was done when i bought the car. when i drive i have this bogging problem like if im crusing at speed the car slows down nd i have to step on the gas pedal to get it going again..i kno my way a honda pretty good but im lost!! checked tps map timing dizzy new plugs wires cap rotor..running on ls computer? idk what to do plzz help i only have 2 wires going to the tps and from what i understand the civic uses a 3 wire set up?? can someone plzz help me!!!
Old Jul 16, 2011 | 05:33 PM
87bimmer325's Avatar
Default Re: helppp plzzz!!! anyone!!
has the car ever ran good? sounds like some sort of misfire how did u check the dizzy, if its got the internal coil there can be like 3 things wrong with it causing it to run crappy, only check with a known working good condition one.
Old Jul 16, 2011 | 07:43 PM
Former User's Avatar
Default Re: ek/ls swap has bogging problem
Thread titles MUST summarize the tech problem (be topic specific) so that members browsing titles can understand the problem without reading the post. Title edited.
Old Jul 17, 2011 | 08:57 AM
I changed the rotor and cap..how do u check the coil..plzz anyone!! Plus does anyone have a wiring diagram for an ls integra
Old Jul 17, 2011 | 09:12 AM
with an ohm meter, or if u have a friend with same kinda car swap it out and find out.
Old Jul 17, 2011 | 09:27 AM
Old Jul 17, 2011 | 01:33 PM
Po1337 code..and I even did the ckf trick both methods and I'm still getting this code..I give up guys I dnt what else to do!!! Car is great other than this bogging. Jerking problem at crusing speeds..plzz can anyone point me in the right direction I chanfed the dizzy like 87 bimmer says still no Freaking luck..
Old Jul 17, 2011 | 01:35 PM
To answer your question I bought the car like that they guy told me to just change the ecu and I did and still does it..only sometimes
Old Jul 17, 2011 | 07:23 PM
can someone please help me on this problem im having with my car!!!
Old Jul 17, 2011 | 07:35 PM
HondaGuy951's Avatar
possibly needs valve job, or bad 02 sensor.
Old Jul 17, 2011 | 10:01 PM
itsnotfast's Avatar
2 Things HondaGuy951.. 1) Your avatar rocks and 2) I'm not saying you're wrong but I've never heard of a bad O2 sensor causing the car to bog. I have heard of a clogged cat causing similar problems though.
Old Jul 18, 2011 | 07:58 AM
checked the valves with a feeler gauge..they seem fine..does cel code po1337 crank flucation sensor no signal cause it to run like that..i did the ckf method and still nothing..ughh driving me nuts
Old Jul 18, 2011 | 11:08 AM
I'm going to order a new CMCC sensor and replace it and c if that works..just hate throwing money at the car ugh..
Old Jul 18, 2011 | 11:09 AM
Ckf*
Old Jul 18, 2011 | 11:11 AM
AsianCivicRider's Avatar
Im sorry to say this but the guy screwed you (not literally).
Old Jul 18, 2011 | 01:54 PM
Lol I don't pay that much for it Soo..I got the better deal car is sup clean wire tuck full suspension nd ac
Old Jul 18, 2011 | 03:37 PM
and currently broken should fetch a nice penny
Old Jul 19, 2011 | 10:22 AM
Lol that code I'm getting the Po1337 crank fluctuation sensor no signal..could it be that its not plugged in or does anybody think its just broken cause I dnt wanna spend 100 dollars if its not..but I dnt wanna tKe it all apart nd it is..people what do u think I should do? Cause if it is I have to special order it
Old Jul 19, 2011 | 10:24 AM
I think that's the reason the car is bogging or jerking like that..does anybody have similar issues? Or what's the symptoms of this code??
Old Jul 19, 2011 | 12:09 PM
anyone?
bigboom
Feb 4, 2010 04:30 AM
crazyimport
Mar 7, 2008 10:57 AM
ekx4
Nov 30, 2006 01:02 PM
JDM-EJ698
Nov 9, 2006 11:05 AM
sporty240
Dec 19, 2005 05:21 PM
