door wont open all of a sudden?
Old Jul 16, 2011 | 01:27 PM
Civic Racer X 7's Avatar
Default door wont open all of a sudden?
out of the blue and all of a sudden today
my driver door will not open
the door lock clicks up and down and "sounds" like something internal is moving and clicking
but the door wont open
is there some way I can open it?
I tried to remove the door panel but it wont come off in closed position
what is goin on?
any ideas?
98 civic lx 4 door
Old Jul 16, 2011 | 03:04 PM
Default Re: door wont open all of a sudden?
Old Jul 16, 2011 | 05:47 PM
no one?
Old Jul 16, 2011 | 06:46 PM
87bimmer325's Avatar
did you try the key? i had a short once that locked my doors and when i would unlock them they would reloc so i took the fuse out. can u take the handle out and tug on the bar. inside or out.
Old Jul 16, 2011 | 06:57 PM
I tried the key it makes the manual lock go up and down but door handle still seems NOT to engage
I tried to remove door handle cover (removed screw) and the cober panel wont budge
weird
Old Jul 16, 2011 | 07:04 PM
hybrid1990crx's Avatar
The lock failed. I've seen this happen before on my friends hatch. He had to remove the door panel and drill through the latch until it let go.....this is how the dealer does it as well. It did not look fun at all LOL.
Old Jul 16, 2011 | 07:16 PM
sounds ****in awesome , how the hell do you remove the door panel with the door shut
Old Jul 16, 2011 | 07:17 PM
the little panel o er the door handle on the inside has to slide left or right there is a hook like thing and then it pops out.
Old Jul 17, 2011 | 06:39 AM
so rip the door panel off and drill the lock out from ths inside?
Old Jul 17, 2011 | 07:10 AM
Former User's Avatar
Do what this guy^ says to remove the inner handle. Also remove the power window switch unit. Through these holes in the door panel, you may gain access to and be able to pull on the inner handle rod and latch rods, which may allow you to open the door.
Old Jul 17, 2011 | 07:40 AM
ok removed both of those components, I did pull directly on the rod that the inner handle was connected to and nothing happened
going to see if I can access anything thru the power window switch hole
lol @ climbing in and out like the Dukes!
Old Jul 17, 2011 | 03:41 PM
well I pulled the whole door panel back enough to get in
all the rods are connected
I moved them all and they seem to work properly
it seems as if the lock latch itself failed internally somewhere
I cant see anyway of getting in there and drilling it out
this is gonna be tough
Old Jul 17, 2011 | 07:42 PM
ttt
Old Jul 18, 2011 | 02:37 PM
anyone else? lol
Old Jul 18, 2011 | 03:35 PM
1.6VTEC's Avatar
the same thing happened in my 93 civic on friday. i closed the door, drove home and couldnt get out when i got home. i've been pulling a dukes of hazzard since then and i seriously am so lost. i tried all of the things you did and got no where
Old Jul 18, 2011 | 04:02 PM
try to get closer to the latch if u can, maybe go t junkyard source a new door, or at least interior panel cut a hole closer to the front to enable you to get to the lock mechanism to try to mess with some more, or drill it grind it whatever u can to remove it to open the door and put a new one on there is probably a better way then this but you sound desperate
Old Jul 18, 2011 | 05:56 PM
I yanked the whole door panel back and could see the mechanism real good
everything looks to be in order all rods connect and operate
all I can think is maybe something internal of the lock mech broke
Old Jul 18, 2011 | 06:09 PM
It's time for small explosives or a BFH.
Old Jul 20, 2011 | 07:30 PM
or sell the car ;-0
Old Jul 20, 2011 | 07:46 PM
Try tapping on the latch while working lock/unlock rod.
Old Sep 14, 2011 | 09:47 AM
1.6VTEC's Avatar
Finally figured out my door. I bought a used door at a junk yard and ripped mine apart from the inside. The lock mechanism was stuck together and just put the used door on once i got mine off.
Rayzorx
May 30, 2011 06:46 PM
hotboxnaccord
Apr 21, 2011 05:46 PM
pstanger
Aug 22, 2007 08:58 AM
kkulseth
Jun 26, 2007 07:21 PM
BB4
Aug 18, 2005 03:39 PM
