Suspension & Brakes Theory, alignment, spring rates....
ground control top hats
Old Jul 16, 2011 | 11:46 AM
gofastgokart99's Avatar
They call me the part of a womans vagina that causes pleasure.
Default ground control top hats
I currently have my car ripped apart sitting on jack stands. I need this thing back together ASAP.
I am trying to assemble my koni/GC combo with the most fvcked up, worthless instructions ever. I can't tell exactly how to assemble the upper half. I have the lower plastic washer and lower bump stop on the lower part of the shaft already. I am trying to install the GC extended top hats on the front struts.
I need someone who has prior experience with suspension to instruct me PLEASE!!!!
I can post pics or whatever or if someone can explain it please do so.
-Garret
Old Jul 16, 2011 | 11:56 AM
grumblemarc's Avatar
The Grumpiest
Default Re: ground control top hats
Top hats are top hats. They all go on exactly the same whether OEM or aftermarket (Ebay or GC). If you're having issues with that then possibly you are doing something drastically wrong. I just put ETHs on a set of shocks yesterday.
Old Jul 16, 2011 | 12:01 PM
thank you for the reply. the bump stop that comes with the top hat does that go on the lower part of the shaft or the upper? I know I am a noob but decided to tackle this and save myself 1 grand in labor to have someone else do it.
Old Jul 16, 2011 | 12:06 PM
The Grumpiest
https://honda-tech.com/forums/suspension-brakes-54/ground-control-tophats-koni-sport-shocks-confusion-2114408/
Old Jul 16, 2011 | 01:57 PM
thankyou, that link really helped.
I have another question, no surprise.
Question: When I put the strut back into the fork, is there a specific way I have to line them up? They defiantly will not go right in with out hitting the fork from the bottom to tap them on. I noticed a small notch on the bottom of the strut.
If anyone has the answer it would be much appreciated.
-Garrett
Old Jul 16, 2011 | 03:21 PM
The Grumpiest
The notch is supposed to line up with the inside split of the fork. On the hatch I have to tap the bottom of the fork with a hammer to get the fork back on.
CRXguy_88
18
Sep 2, 2011 08:39 PM
der3k
Suspension & Brakes
Feb 23, 2010 12:31 PM
bonh
Suspension & Brakes
Sep 28, 2009 05:26 AM
vicsta
Dec 4, 2008 05:13 AM
bobmugen
Suspension & Brakes
Sep 29, 2008 01:03 PM
