Help save my GS-R
Old Jul 16, 2011 | 10:59 AM
hamilton9339's Avatar
Icon2 Help save my GS-R
I have a 92 GS-R last night i was driving it after changing the oil an adding engine restore rolling about 80 on the highway shifted to 5th an immediatly loss some power shifted down to 4th an gained alittle rpm the check engine light cam on an the car started dying i pulled off an exit just in time for the oil light an battery light came on the car died got it into the parking lot checked oil it was good do have a leak but its not dumping out think its a pan seal the car sounded good before it died i went to restart an it started rough gotta give it gas to stay running which in turn allows you to here the nice knocking/klacking sound in the motor i was told valves or rod bearing how do i determine which an where should i go from here..............oh an now the car dont turn over at all has full power you turn the key an everything turns on an off but no turning of the motor HHHHEEEEEEELLLLLLLLLLLPPPPPPPPPPPPPPPP!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
Old Jul 16, 2011 | 11:13 AM
mouab18c1's Avatar
Default Re: Help save my GS-R
Drain the oil to look for metal shavings and do a leak down test.
Old Jul 16, 2011 | 09:32 PM
Mattcuzko's Avatar
i dont know much and cant help. but good luck man. hope you can fix it.
Old Jul 16, 2011 | 09:36 PM
boarding2008's Avatar
also see why you are throwing a check engine light
Old Jul 17, 2011 | 05:12 PM
UPDATE: I took the valve cover off took it to tdc an it was off 1 tooth belts loose an slipping readjusted started fine belt slaps bad so i shut it off till I get the new belt, pump an tensioner
Old Jul 18, 2011 | 12:12 AM
KILLAB17VTEC's Avatar
Genetically Gay
time to take the car to auto repairshop.
Old Jul 18, 2011 | 05:02 AM
Dogginator's Avatar
Daisy... Daisy...
Check your valve adjustment. If you have any really loose valves, you most likely bent them. You may have been fortunate. I would tell you to run a compression test, but I think that rotating your engine with the starter at this point is a bad idea.
MilFhunter001
Mar 1, 2011 10:08 PM
kris9
Dec 29, 2009 12:22 AM
skunkcoupe
Aug 10, 2007 04:22 PM
skunkcoupe
Aug 10, 2007 05:21 AM
Tru Dynamix
Jul 23, 2003 10:53 PM
