Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 LX 4-Door Grounding Issues
Old Jul 16, 2011 | 10:51 AM
Kwicko's Avatar
Default 2001 LX 4-Door Grounding Issues
Hi all - Long time, no see!
So I picked up a 2001 Civic LX 4-foor for the wife, and it's got an odd grounding issue, as far as I can tell.
When you've got the car running with the A/C on, it will sometimes (like when you step on the brake, but not every time) seem to "cut out" for just a second - the lights dim, the A/C cuts out and then everything comes back on. It does it more, the more accessories you've got on - lights, A/C, high beams, brakes, etc.
Seems to be a pretty obvious grounding issue, but I'm not finding the break. I checked the ground from next to the valve cover to the rad support, the one from chassis to trans case, but what others am I missing?
Any helpful tips would be much appreciated.
Mike
Old Jul 16, 2011 | 02:18 PM
lazlong's Avatar
Default Re: 2001 LX 4-Door Grounding Issues
-Behind both inner fenders
-Left (driver's) side of the engine
-Under the gauges
-Under the front portion of the center console
-Several behind the dash. Take off panels and start looking.
CarbonRust
Sep 4, 2014 08:32 AM
nike215
Mar 19, 2008 10:35 AM
JohnBham
Aug 31, 2007 10:52 PM
Monkdann
Dec 3, 2004 04:55 PM
Sniper@ImportRacing.Ca
Apr 30, 2002 05:54 PM
