Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Honda Civic LX help.
Old Jul 16, 2011 | 10:03 AM
OvertheCliff79's Avatar
Default 2001 Honda Civic LX help.
I have a 2001 Civic LX with 148k on it and I've been having a problem starting it from time to time. Sometimes it starts up fine and others it turns over and sounds like it's going to start but then dies then I do give it a little gas and it starts right up. It's also idling at about 500-600 rpms and it vibrates the car when idling but if I give it a little gas it's smooth.
The check engine light has been on and it flashes sometimes when I'm stopped just idling.
Just looking for some idea's of what it could be... fuel pump/filter? fuel injectors? timing belt? Any help would be great. My dad and I just changed the spark plugs, and adjusted the valves.
Old Jul 16, 2011 | 10:05 AM
Default Re: 2001 Honda Civic LX help.
Oh additional info there are 4 check engine codes that come up and they are all of the misfire ones. In each of the cylinders. But the engine isn't misfiring at least doesn't sound like it is. I'd think you'd notice by sound and performance. It drives just fine once you get out of idling.
Old Jul 16, 2011 | 03:04 PM
shantech's Avatar
go get a tune up change your fuel filter. what ever the problem is thats causing the misfire is a part thats linked to all cylinders
Old Jul 16, 2011 | 03:49 PM
civichxtreme2's Avatar
Agreed, sounds like a fueling issue. Change Filter as stated above and report back.
ISUBIEXI
25
Apr 11, 2017 07:20 AM
capm.stabahoe
Dec 27, 2008 06:17 PM
brimy311
Jul 28, 2003 04:39 AM
Lonny
Apr 13, 2003 01:12 PM
