First Head Gasket=Fail
Should I remove head and use a straight edge on both? or is that not accurate enough? I shouldn't have skipped that step anyways.
I should also mention I have been using very poor compression testers, the one I borrowed from autozone is completely bust.
Well if you're blowing white I would think there is definitely a sealing issue with the gasket. The only way you'd be sure to get a good seal is take the block and head to a shop for resurfacing. Oh and you should avoid re-using the head gasket you just installed.
MigsD16
Engine Machining & Assembly
Dec 17, 2016 05:17 PM
b16t4turbo
15
Apr 2, 2006 08:37 PM
