throw out bearing or input shaft bearing??
Old Jul 16, 2011 | 05:31 AM
95BG33PGSR's Avatar
Default throw out bearing or input shaft bearing??
here's the symptoms:
At first with the clutch engaged (pedal up) at idle it makes a knocking sound but when I push the clutch in, the sound goes away, and above about 3500 rpms it made a whinding noise.
Now I hear a chatter type sound when the clutch disengaged (pedal down) and it is really hard to put it in gear and when it goes go into gear i hear a grinding noise and the car seems like it wants to stall out.
clutch is a clutchmasters fx400 and only has roughly 5,000 miles on it...
what do you guys think
Old Jul 16, 2011 | 06:47 AM
Kr4nG's Avatar
Default Re: throw out bearing or input shaft bearing??
well you have to take the tranny out either way so start by doing that. once you have it out you can check if your clutch springs arent broken or missing and you can check your input shaft as well by spinning it by hand. and of course your throw out bearing following your pilot bearing.
Old Jul 16, 2011 | 08:14 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ no matter what, you will need to pull the tranny, it kind of sounds like a broken clutch spring(s). 94
Old Jul 16, 2011 | 11:15 AM
el crapitan's Avatar
yup. clutch spring(s) would be my guess.
have to pull the trans for further inspection
Old Jul 17, 2011 | 05:06 AM
95BG33PGSR's Avatar
Yeah i had a flatbed come and pick it up yesterday to take it to a tranny shop, i would do it myself, but i have a newborn at the house with a two year old and my wife got sliced open so i can't leave her alone for too long, she's trying to heal....
what would cause the spring(s) to break? the clutch only has around 5,000 miles on it? I'm not even really hard on it...becides city driving that is
Old Jul 17, 2011 | 07:58 AM
fcm's Avatar
fcm
Old Fart
Could just have been defective, it happens.
It may be due to improper installation, also happens. 94
Old Jul 17, 2011 | 08:10 PM
Integra4lyfe069's Avatar
your isb is shot too.
cause if sounds go away when its in tats ur isb blown.
the grinding is the clutch springs.
so seems u have more then one problem here.
Old Jul 18, 2011 | 12:22 PM
TYLER3's Avatar
you should pm me the cost of this fix because my teg just started to do this the other day too and i just took it in to a honda dealership. so im thinkin they are gonna charge me a lot.. damn
Old Jul 19, 2011 | 03:22 AM
95BG33PGSR's Avatar
the shop figured it out...the throw out bearing was bad, but on top of that, a couple of the flywheel bolts loosened up and backed out and somehow tore up the face of clutch disk (including the springs), and one bolt was hanging out a lot and was preventing the pressure plate from pushing down all the way...this sucks because he said the friction pads were still "mint", and a couple of the dowl pins here messed up i just put this bad boy in last fall so there was 500 down the drain...
I don't know why the bolts would have backed out, i used locktite and torqued them all to spec.
im gonna go up there later and take pics
ISB is perfectly fine...thank god
wessieball
Feb 25, 2009 12:44 PM
mr_nemesis2003
Nov 14, 2006 01:04 PM
FlsFinest
Jun 21, 2005 08:49 PM
Ditdogs
Apr 17, 2004 10:57 PM
