Suspension & Brakes Theory, alignment, spring rates....
Wilwood 140-6163 (12.19" Rotor/4-Piston)1
Old Jul 15, 2011 | 09:04 PM
PreyStayShun's Avatar
Default Wilwood 140-6163 (12.19" Rotor/4-Piston)1
Work with a 16" wheel, Ive read so many different answers I'm not sure what to believe! :-/
Wilwood's site says it'll work with some 15" wheels, summit racing says it'll only work w/17" wheels...
Any ideas....
Old Jul 16, 2011 | 07:55 PM
DB2-R81's Avatar
25 Year Member
Default Re: Wilwood 140-6163 (12.19" Rotor/4-Piston)1
Under a 16" wheel:
Under a 15" wheel:
Old Jul 16, 2011 | 08:32 PM
Thanks bud, I appreciate that.
Old Jul 20, 2011 | 10:23 PM
hybridnorth's Avatar
I have the 6 piston 12.19" setup with 16's. You can run 15's with the 4 piston as it doesn't take up too much space.
Old Jul 22, 2011 | 09:13 PM
koczeka's Avatar
No go on 15inch wheels. Only the 11" version fits under. 16inch wheel for the 12.19" set.
Old Jul 22, 2011 | 09:51 PM
DB2-R81's Avatar
25 Year Member
You are wrong and don't have a clue, I can name TE27, CE28, Team Dynamics Pro Race 1 and 2's...............wheels these brakes will fit under.
Look at the picture I posted above: 15 X 7" wheels!
Old Jul 23, 2011 | 08:40 PM
koczeka's Avatar
I am currently running them with 16x7 Volk CE28. I am right.
Old Jul 30, 2011 | 07:54 AM
Mr. Carbon Fiber's Avatar
Originally Posted by DB2-R81
Under a 16" wheel:
Under a 15" wheel:
What offset are you running for the 15" and the 16" Wheels DB2-R81? Those info are important as well for the caliper to clear the spokes of the wheel. I have the same WW kit but no on the car yet. Running 16x7 +39 offset Weds Sport SA70.
Old Jul 30, 2011 | 08:44 AM
DB2-R81's Avatar
25 Year Member
Here you are Mr. CF:
The Mugen MF8 are 16 X 7" X +43mm
The Pro Race 1 are 15 X 7" X +23mm
The Pro race wheels are a low offset to clear the 23 X 9.0 X 15" cantilever slick tires I compete with not the brake calipers.
Old Jul 30, 2011 | 12:36 PM
Thanks for the helpful info DB2-R81!!
Old Jul 31, 2011 | 10:52 AM
phunhaus's Avatar
16" SSR Competition:
I cannot stress enough that the SPOKE PATTERN and BARREL DESIGN play a more important role in caliper clearance than offset does.
Case in point: my TE37 and Regamasters (+33 and +35 respectively) cleared my RL calipers whereas my GAB Sport (+38 and even a +22ish) would not and my Enkei J Speed III +25 needed to space the wheel 10mm to clear the inner barrel. Some wheels are designed with a larger barrel while some have a stepped barrel for whatever reason. I won't pretend to know and say it's for wheel rigidity. Just understand some wheels are shaped differently where it counts.
Old Jul 31, 2011 | 07:02 PM
DB2-R81's Avatar
25 Year Member
It is called a drop center and it is there so the bead of the tire can be mounted on to a rim, without it you would never get a tire on a wheel.
Old Jul 31, 2011 | 11:44 PM
wannaBjdmca6's Avatar
they work under sprint hart cpf which i am selling
http://forums.nwp4life.com/zerothread?id=26509&page=1
Caddiman
Dec 13, 2012 09:37 AM
Rim_Repairs
Welding / Fabrication
Jul 7, 2008 08:32 PM
SlowB16
May 27, 2008 02:44 PM
spooledhonda
Nov 13, 2007 11:15 PM
