ls vtec wont start help please
Old Jul 15, 2011 | 04:43 PM
Haccord1996's Avatar
Default ls vtec wont start help please
Ok whats up honda tech
Block is std size bore machine shop just honed and put OEM CTR PISTONS WITH NEW RINGS.Basically whole bottom end new. The gsr head has manley valve train with super tech valves.
My problem is car doesnt want to start. Has spark and fuel. i did a compression test cyl 1 160 cyl 2 140 cyl 3 140 cyl 4 160 so i poured very very little old in all 4 cylinders and they jumped to 210 still didnt start and now they back down to 180,150,150,150? also as i crank car wants to start but in the begginging i was getting alot of smoke coming out the dip stick now it calm down please someone guide me??????
Old Jul 15, 2011 | 04:48 PM
chase4494's Avatar
Default Re: ls vtec wont start help please
dosent sounds like a comp issue mine had comp probs and would still fire up. how did you check if you where getting fuel ?
Old Jul 15, 2011 | 04:50 PM
Former User's Avatar
Is there bright white spark at all four plugs? Will the engine start with starting fluid? Are the plug wires installed in the correct firing order? Is the mechanical timing right?
Old Jul 15, 2011 | 05:05 PM
chase4494 yea with that compression it should start...RONJ i acutally just checked one plug that would have to be my next thing check all. And yes timing is on the money. and i had no starter fluid will have to go buy some tomorrow thanks any other suggestions?
Old Jul 15, 2011 | 05:13 PM
chase4494's Avatar
has this car ran before ? or have you changed the harness recently ? if so check your ground on your water neck/head/tanny.
Old Jul 15, 2011 | 05:16 PM
no i had a gsr i swapped now to lsvtec so this motor never ran yet
Old Jul 15, 2011 | 05:22 PM
firing order is right and grounds are good ill double check tomorrow guys thanks alot i apreciate it B20VTEC .COM OFFICALLY SUCKS
Old Jul 16, 2011 | 03:11 AM
update guys forgot to say yesterday that im also getting a CEL 6 short blinks followed by 1 long one i dont know if its code 6 and code 10 or code 16 for fuel injector but my injectors are plugged in
Old Jul 16, 2011 | 05:47 AM
Post a video of the blinking CEL.
Then clear the codes from the ECU to see whether they return after cranking the engine.
Old Jul 16, 2011 | 05:50 AM
Wrona's Avatar
try ceckin your fuel filter
Old Jul 16, 2011 | 09:11 AM
siR_ish's Avatar
code 16 is fuel injector , code 10 is air temp sensor, code 6 is coolant temp sensor
Old Jul 16, 2011 | 02:51 PM
got the car to start.. runs but stalls out after a while but if i take out the vaccum hose from regulator off it runs all day... now i found the tps sensor one of the wires broke ff so now gotta figure how to fix that and if i rev little i cant pass like 2 grand i know cuz tps is unplugged but im getting white smoke out the exhuast???
Old Jul 16, 2011 | 02:52 PM
ron j i know its flashing defintely 6 short blinks then pauses then 1 long blink
Old Jul 16, 2011 | 02:58 PM
forgot to add right now i have 30 w non deg oil ?
Old Jul 17, 2011 | 02:20 AM
anything guys
Old Jul 17, 2011 | 06:51 AM
How did you get the engine to start?
If you are sure codes 6 and 10 are thrown, then fix them and go from there. Are the ECT and IAT sensors connected? A broken TPS wire should throw a TPS code. Look for swapped sensor connectors.
Old Jul 17, 2011 | 02:11 PM
dizzy wires was crossed....and yea it blinks for sure 6 times fast then short pause and then once long so it should be 6 and 10 and intake air is connected and so is coolant??
Old Jul 17, 2011 | 03:40 PM
ok guys went to check the sensors coolant is plugged in and one thing i just realized i never had a intake air temp sensor plugged in why would it throw a code now? could it be im using the chipped p28 that was tuned on my previous gsr motor ?
Old Jul 17, 2011 | 03:55 PM
yes i do its on the tb but the the ecu be the issue i dont get it all i deid was swap blocks men
Old Jul 17, 2011 | 04:01 PM
also car takes a while to start when cold have to step on throttle for it to start ?? smh went from a smoking gsr to a ****ed up lsvtec men
redmon_e
Jan 5, 2015 11:47 AM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
CuteAccord
37
Jan 3, 2009 10:41 AM
de1991hatch
Jan 10, 2008 05:10 PM
Bngo731
Jun 5, 2006 02:42 PM
