Complete b16/itr swap
Up for sale is my B16/ITR swap it is 95% complete here's the info..
Head-
97 PR3-2 Integra type r head
buddyclub titanium valve springs/retainers - 300 miles
supertech flat face high comp valves - 300 miles
aebs intake manifold/b16 tb - aebs is new
Jdm b16 cams and gears
Integra type r throttle cable and bracket - new
new intake and tb gaskets
high flow fuel rail
Brand new headgasket and timing belt
New distributor and plugs, wires
3 inch intake with filter
Shaved valve cover
stock exhaust manifold with heat shield
Bottom end-
Jdm b16 obd1 runs good super clean
1.6 babeh
Trans-
New clutch and new pressure plate oem replacement
EM1 trans has vins on it WOW
shift linkage
axles and shaft one axle is new one has low miles
I have a eg rear mount and a si mount as well as 99-00 stock si mounts
If you want to run the motor obd1 I have a jdm p30 as well as a new obd2b-obd1 ecu jumper and rywire distributor jumper new as well
I have some money into this as well as a lot of time bought everything legit not from some random guy from little mexico lol.
I want 1600 for everything not parting or anything only thing I might do is trade for a sohc swap and money but I must see t run. Ill have pictures up soon.. I have many vouches let me know if your interested. Will have pictures up tonight sometime as well as the trans vin#
Ill have more pictures or everything the swap is like half way in my car. If someone wants i can set the timing and what not its just off in the pic.
Head-
high flow fuel rail
Shaved valve cover
Bottom end-
1.6 babeh
Trans-
shift linkage
jdmej814
May 31, 2009 07:13 PM
herde1724
May 1, 2006 06:29 AM
