Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
i've said it before and i'll say it again
Old Jul 15, 2011 | 12:46 PM
Lo-Buck EF's Avatar
Default i've said it before and i'll say it again
I HATE MY HONDA!
makes
Time to build H2 engine #4 (or 6 depending on how you count them).
Old Jul 15, 2011 | 01:01 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: i've said it before and i'll say it again
Ouch that sucks.....
Old Jul 15, 2011 | 01:24 PM
bokals's Avatar
Looks like Chug-a-lug chocolate milk
Serious note, what happen?
Old Jul 15, 2011 | 01:56 PM
Egezzy's Avatar
Spongebrad Squarepants
he holeshots every race he is in so his competitors came equipped with banana peels and turtle shells. he got hit by a red turtle shell this go round.
Old Jul 15, 2011 | 02:06 PM
dirty19's Avatar
Ridin Dirty in Cali
Did that piston split Spence?
What engine are you running?
Dont hate your honda... go hug it and tell it that everything is going to be ok.
Old Jul 15, 2011 | 03:16 PM
jdm_AE86's Avatar
I just started racing and i think about **** like this all the time. You know the shitty part? it WILL happen one day lol.
Good luck with whatever you got planned next, keep on keepin on dude.
Old Jul 15, 2011 | 03:25 PM
Spitfire8o5's Avatar
Tough Luck man, improvement time!!
Old Jul 15, 2011 | 04:48 PM
Lo-Buck EF's Avatar
after a night of staring at it and pondering, i think the chain of events is as follows.
1. ears of dizzy (that go into the cam) broke off the first weekend of testing. couldn't find them. weird.
2. missed a shift at hyperfest 2010 on the start (2-3-2 and still finished the race) but had lots of bent valves and cracked guides. found those dizzy ears when i took the head appart tho. they had been grinding on the cam a little bit and put some metal flake in the oil. ggrreeaatt.
3. got it running after the epic fail season of brake problems only to melt some plugs due to the cam timing being WWAAYY off.
4. it started using oil all of a sudden at a test day a few months back and then picked up a miss before sunday's race at hyperfest. it made it till 2 laps before the checker before it went b00m.
the piston failure is mechanical. had it melted down from detonation, it would have gone for the exhaust side (usually) and it would have put a hole, not a fairly straight 'cut' in the piston. i haven't torn the bottom end completely appart just because i don't care. that one is going to the machine shop for a turbo build the next time it sees the light of day.
sad, i have more wrenching hours in this car than i do drive time. WWAAYY more.
Old Jul 15, 2011 | 05:00 PM
known's Avatar
uggh that sucks
Old Jul 15, 2011 | 05:05 PM
dirty19's Avatar
Ridin Dirty in Cali
Might be time for a Brian Zoraster build?
He builds some bullet proof engines.
Old Jul 15, 2011 | 05:08 PM
Lo-Buck EF's Avatar
eh. i'm too cheap to have someone build me an engine. hopefully the head can be fixed (that piece of ring didn't get flat all by itself) and i hope to have a new bottom end in a couple weeks.
its a gsr
Old Jul 15, 2011 | 05:20 PM
dirty19's Avatar
Ridin Dirty in Cali
its a gsr
Spence,
At least contact him and inquire how he does it.
Nothing wrong with a Spence build.. but man this guy has never had an engine fail on him.
Old Jul 15, 2011 | 05:42 PM
Lo-Buck EF's Avatar
honestly, if i hadn't zinged it, got a bunch of metal in it and almost melted it it would still be running. but you are right. nothing wrong with more info.
Old Jul 15, 2011 | 09:21 PM
h46it's Avatar
Sorry to hear
Old Jul 16, 2011 | 03:10 AM
descartesfool's Avatar
You're hard on your engine, that poor thing, amazing it survived that long!
from looking at your piston, all I can say is "that's gonna be expensive", and a lot of work, having just done that myself.
Stuck wastegate, unlimited boost, for a short while anyhow, it was amazing while it lasted, boost needle pinned. Broken piston made a fantastic oil pump, spewing the entire contents of the engine onto the track in just two corners. So much time and money.
Old Jul 18, 2011 | 01:23 PM
1998GsRIntegra's Avatar
Definitly right there with you on that one.
Old Jul 18, 2011 | 01:30 PM
rice_classic's Avatar
Running H2 sure looks expensive.
Old Jul 18, 2011 | 01:48 PM
chad's Avatar
Moderator
i have engines
Old Jul 18, 2011 | 02:55 PM
Lo-Buck EF's Avatar
u know what i need. call me when u get one in stock....
Old Jul 18, 2011 | 07:58 PM
smokin rubber's Avatar
nice one spenc, how high were you revving that gsr before it went?
Old Jul 19, 2011 | 12:31 AM
Lo-Buck EF's Avatar
8500 but when i over reved it last year it was over 10,000
Old Jul 19, 2011 | 12:39 PM
mrlegoman's Avatar
fix it with fire
Old Jul 19, 2011 | 01:54 PM
Lo-Buck EF's Avatar
burn'd to the ground
Old Jul 27, 2011 | 12:17 PM
slammed_93_hatch's Avatar
Why because one guy has really bad luck with motors??
The parts/rebuilt cost isn't much if any different between a H4 motor, and say a H2 motor.
I've done both, D16z6(h4) and k20a3(h2).
Spenc,
I question the fact that you "don't have the money to 'build' a motor", but you've had the money to slap together/buy parts for 4/6 motors.
Spend the money in the right spots, on the right stuff, replace the wear items, upgrade the head studs/valve springs, get a good valve job, and be done with it.
Combined the money you spent on the heads/blocks/cams/etc, and the massive amount of time you've spent pulling/tearing apart/re-buidling 4 times over, don't forget to add in the $$ you 'lost' on not getting to race, wasted gas to and from the track etc. And i don't know how you could not have spent WAY more then $2000, which is more then a build/rebuild will run you.
Old Jul 27, 2011 | 01:14 PM
Redcivic92's Avatar
HT White Ops
I totally agree on spending money on the right stuff. That being said I think this is the 1 and only engine Spence has had in the car and he has the BEST head work done on his engine. He will be getting a new block this week and hopefully be back on track soon.
