custom bracket. ls tb on gsr manifold in ls integra
Old Jul 15, 2011 | 12:44 PM
ivan93egreppin210's Avatar
Default custom bracket. ls tb on gsr manifold in ls integra
cant find a used gsr tb and bracket anywhere and a friend said i should build a bracket for my ls tb . does anyone have pics?
edit: forgot to mention the motor is a b20z2 with a gsr head. im going to be using the throttle body from the b20 (same as ls hence the title).
Old Jul 15, 2011 | 01:38 PM
Muckman's Avatar
Moderator in Chief
Default Re: custom bracket. ls tb on gsr manifold in ls integra
Why do you need a TB bracket? Are you talking about the throttle CABLE bracket?
Old Jul 15, 2011 | 01:52 PM
in order to use my b20 tb, i need to run the cable under the manifold. i need some sort of bracket to hold the cable under there. don't know if that makes any sense.
it would be 1000X easier with a gsr tb but that's not an option until at least next week and i cant wait. need a quick short term fix
Old Jul 15, 2011 | 04:03 PM
Muckman's Avatar
Moderator in Chief
Ok I understand now. Short term fix I would get a small sheet of metal and make something that will fit. It doesnt have to be pretty.
Old Jul 15, 2011 | 06:01 PM
i did it. works like a charm. i made a 10 sec vid to show what i did. hope this helps someone else.
http://www.youtube.com/watch?v=eSInY67dEEg
Old Jul 16, 2011 | 04:23 AM
HondaPartsHero's Avatar
Technical Hero
Plumbers strap, I've used this in the past with good results and its only a couple of bucks for a roll.
Old Jul 16, 2011 | 04:32 PM
yes sir. i used basically the same thing. found a piece of metal and made two holes. one mounted to a manifold bolt and the other to the ls bracket. distance of bracket to TB was perfect. no slack. thanks
Old Jul 17, 2011 | 02:35 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
gotta love functional ghetto fixes to hold you over until you can get a better solution lol
bmoreb18c1
Sep 10, 2013 01:41 AM
sc34dc4
Oct 13, 2010 04:00 PM
type Gendy
Mar 21, 2006 05:30 AM
b16clutch
Dec 28, 2005 09:55 AM
dragsol
Jan 27, 2003 06:54 AM
