2000 RPM idle after freeway drive
Old Jul 14, 2011 | 05:41 PM
thewrai6th's Avatar
Default 2000 RPM idle after freeway drive
I have an odd problem that maybe someone has experienced before. This is the second time in about 1 month.
Setup:
See sig, -turbo (NA right now), stock compression, stock cams, stock ecu/injectors
After driving home from work on the freeway, I pull off the exit ramp and my idle is stuck at 2000RPM. I rev it a bit and it barely drops at all. I stopped and let it sit for about a minute or two and the idle dropped to ~800.
The temp was exactly at normal, the fan cycled a couple times while sitting there.
On the freeway, when I would let off the gas to decelerate, sometimes it would feel like it was still getting some gas, or a blip in the throttle.
Any ideas or experiences with this issue?
The freeway was crawling at 50 or so, maybe she was just angry?
Old Jul 14, 2011 | 07:14 PM
MechEng's Avatar
Default Re: 2000 RPM idle after freeway drive
Clean the Idle Air Control Valve
Old Jul 15, 2011 | 05:46 AM
dntnedvtec's Avatar
Either that, or your throttle body is sticking
Old Jul 15, 2011 | 06:00 AM
fcm's Avatar
fcm
Old Fart
IACV, TPS, or sticky TB, check all three. 94
Old Jul 15, 2011 | 06:40 AM
HondaPartsHero's Avatar
Technical Hero
Throttle cable slack as well
Old Jul 15, 2011 | 10:11 AM
thewrai6th's Avatar
Thanks everyone, looks like I have a small project for the weekend.
I don't think it was the throttle sticking. I pulled up on the gas pedal and the slack in the cable is ok. Could be a bad TPS, but my guess is that is will be the IACV. I have some hunting idle issues when I startup hot and I've never cleaned it before.
Old Jul 16, 2011 | 12:57 PM
thewrai6th's Avatar
The IACV screen was completely clogged. I cleaned it out and now... the idle problems are 100 times worse. The car barely starts and if I even turn the steering wheel it stalls.
I reset the ECU, with no luck.
Old Jul 16, 2011 | 01:16 PM
thewrai6th's Avatar
I unplugged the IACV and set the idle to ~650 with the adjusting screw. It was turned all the way in, probably to compensate for the dirty IACV.
z0mby
Oct 22, 2011 04:32 PM
dc2_916
Mar 10, 2008 06:20 PM
Bizarre
Sep 6, 2007 09:40 AM
Hyaboosta
Mar 10, 2005 09:36 PM
stRodda
Jan 13, 2004 04:32 PM
