Enkei 92 on EF
Old Jul 14, 2011 | 03:43 PM
Henry14000's Avatar
Default Enkei 92 on EF
Hey guys. Im planning on buying a set of enkei 92 (15x8 +25). Just wondering what kind of work will be needed. Will rollinig my fenders be good enough? Im trying to avoid pulling my fenders. Also, if anyone can post pics of an EF with such a wheels size. 15x7 is good as well.
Thanks
Old Jul 14, 2011 | 06:27 PM
1990edsedan's Avatar
Default Re: Enkei 92 on EF
With that offset and rim width you should be able to get away with rolling your fenders. What is missing in the equation is what size of tire are you going to run?
Old Jul 14, 2011 | 08:03 PM
Mr Lee5353's Avatar
Depending on how low you are and what tire size you run I'd say you'd be fine with a roll. Maybe just a slight pull. The ole' news paper pull trick would probably work fine. I'd say no larger width than a 195/50 tire though. It may be "unspoken" around here but I plan to run a 165/50 on the 15x8's I'll be getting in the near future.
Old Jul 15, 2011 | 07:54 AM
MRN1120's Avatar
They should fit with 195/50
90efzc
Jun 1, 2011 05:14 PM
EF001282
Feb 10, 2008 07:28 PM
CWBETB
Apr 19, 2007 04:52 PM
SpoonPL
Nov 30, 2001 09:30 AM
