SKUNK2 FRONT CAMBER KIT will this fit?
I've been having camber issue with my car for a long time. I once heard before that this kit will fit 94-97 accord? I would like to know if any one has tried this on a accord or if it does it fit? Any help will be appreciated.
Here is a link to the product:
http://cgi.ebay.com/ebaymotors/ws/eB...m=390326910225
Nobody has tried the DA Skunk2 UCA kit. But there is one guy who did use the stock DA UCA on his Accord as EF and DAs are very very similar.
I know tons of Accord guys use the EF Skunk2 UCA kit, but reason they are running these are to get more negative camber for their aggressive offset wheels and of course you need to get it aligned for the tires to wear in evenly. I recommend you to get the Ingalls Anchor Bolt or Balljoint kit if you're not running big offset wheels.
Ok thanks that's what I wanted to know. Got couple of questions, the Ingalls that you mentioned will help the upper control arm not hit inner fender?
This is the kit your talking about right?
http://cgi.ebay.com/ebaymotors/INGAL...9#ht_956wt_939
If so how can you take the ball joint out when it's complete with the upper control arm?
Help would be appreciated.
lightningfield
17
Apr 14, 2008 08:41 PM
MidwestSi
Mar 9, 2005 04:15 PM
