00 Civic/B18C1 - dissapointed with 1/4 mi time, any suggestions?
Old Jul 14, 2011 | 07:39 AM
NOOdS's Avatar
Default 00 Civic/B18C1 - dissapointed with 1/4 mi time, any suggestions?
i timed my car last year when i just got the swap in. everything was stock on the motor, and i ran a 15.6 bone stock. since then ive put in alot of parts, but i didnt get a big gain in speed as i was expecting. i timed my car last night and did a 14.9. i was told when i got my tune, that i needed bigger injectors because i pretty much maxed out the stock injectors. and im hoping thats the reason why, so i can release the power that ive been expecting. i know im not the best driver but the difference between the two times i ran should be greater. is there any recommended parts i should add to my support my setup? or will bigger injectors do the trick? or is my setup meant to run roughly 14.9s?
2000 civic hatch
2000 B18C1
injen cai
skunk2 im
hondata im gasket
jdm itr header
magnaflow high flow cat
apexi ws2 exhaust
skunk2 tuner 1 cams
itr pistons
tuned p28
Old Jul 14, 2011 | 08:02 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 00 Civic/B18C1 - dissapointed with 1/4 mi time, any suggestions?
I think you want this forum.
https://honda-tech.com/forums/drag-racing-36/
Old Jul 14, 2011 | 08:13 AM
NOOdS's Avatar
thanks, ill try over there.
NOOdS
Jul 15, 2011 09:41 AM
Hoffy
Aug 15, 2005 11:10 PM
obd2gsr
Aug 21, 2004 10:14 AM
GsR HtCh
15
Nov 15, 2003 12:46 AM
