will these sway bar bushings work on an accord?
Old Jul 13, 2011 | 06:56 PM
nicolaselias's Avatar
Loved
Community Favorite
Default will these sway bar bushings work on an accord?
Hi everyone,
My accord is RHD from Japan, located in the Caribbean.. Came stock from the factory with 27mm front sway bars and I am having trouble getting this exact size in the Honda catalogue..
Do you think that these ES sway bar bushings look like the design of Honda bushings? It is the correct size, I am just wondering if the design is identical/similar enough to bolt up to my stock 27mm bar..
They are not particularly expensive on amazon, I just need to figure out if they will fit before I order..
Thanks
Old Jul 14, 2011 | 04:28 AM
SQ is the SQUAD's Avatar
Default Re: will these sway bar bushings work on an accord?
make sure you are looking at an actual picture of the product. energy suspension uses a lot of "stock" photos. you parts may differ. the ones pictured do look a lot like the honda bushings. but dont the honda bushings have a slot cut into the flat part??
Old Jul 14, 2011 | 08:31 AM
Loved
Community Favorite
Well, i looked up multiple pictures and they all come back looking like this, so I guess its the correct one..
I'm not sure what you mean by a slot.. You mean the cut that allows you to slide it onto the sway bar? All bushings have that so that you can get it mounted...
Part number is Energy Suspension 8.5118G
Old Jul 14, 2011 | 02:06 PM
adamkerrnz's Avatar
I think some bushings you need to cut that slot yourself
Old Jul 14, 2011 | 02:55 PM
Loved
Community Favorite
I know how urethane bushings work... I have used them before on other cars and once they are well lubed I have never had any problems..
Also, I cant get stock ones seeing as my bar is 27mm and all the other accords I can find are 22 or 25mm..
So, back to the question about the shape of the polyurethane bushings.. Do they look like they will fit these older honda sway bars..
Old Jul 14, 2011 | 04:03 PM
usdmftw's Avatar
yes they "look" like they will fit but going to be hard for anyone to positively say yes. can email seller and ask what the inside diameter of the bushing is?
Old Jul 14, 2011 | 06:08 PM
CDelgado220's Avatar
I'd verify with the company. Email so you have proof.
Old Jul 15, 2011 | 08:13 AM
Loved
Community Favorite
Well, the company is amazon and there can be no "proof" really.. I am purchasing for a non-USDM application so regardless of what they tell me it won't really do me any good.. All I know is that they are 27mm
As I said, they are relatively cheap so I can take my chances and possibly return the item if it doesnt work, but I'd still really like to avoid all that drama...
Old Jul 15, 2011 | 11:24 AM
chikin pickle's Avatar
Originally Posted by Nicefeet
Unless you're running 9/10th buy stock ones. Urethane is noisy and wears like ****
If you don't follow the instructions it does. Needs lube.
Those are stock style grommets. They will probably work. But trust me, you want energy suspension part number 16.8105. The end link set. Twice as beefy as the stock hardware. Made an enourmous difference on my car and I have only done the end links.
For the bushings, you will have to order one of their universal bushing sets. They do make a bushing for a 27mm sway bar. You will just have to use their brackets is all.
Old Jul 15, 2011 | 03:50 PM
Loved
Community Favorite
If you don't mind me asking, how come I will need one of the universal bushing sets if my brackets are designed for 27mm?
I know that the universal comes with its own brackets but what is wrong with mine exactly?
Also, concerning the beefier endlinks.. I'd love to pick them up but I have prothane replacements as well, so any extra endlinks i get my hands on are just spares..
Old Jul 15, 2011 | 07:39 PM
Well if you already have them (endlinks) then use what you have.
There isn't anything wrong with your brackets per-se. If they fit you can re-use them no problems. But what you might run into is that the outer diameter of the universal bushings might not the the same as the stock bushings and they may not fit in the stock brackets. That's all.
Old Jul 22, 2011 | 02:56 PM
Loved
Community Favorite
I called ES today...
They said that the 27mm I mentioned is not going to work and the closest match would be this universal part..
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
He said there is no guarantee but its the closest thing they have...
I tried calling prothane as well but apparently they dont open past noon on a Friday..
Closest thing from prothane i think would be this:
nicolaselias
Jul 4, 2011 03:26 AM
dgerej2
Suspension & Brakes
May 21, 2010 05:55 AM
honda93
Jul 3, 2005 04:53 PM
lemansteve
Suspension & Brakes
Jan 8, 2005 11:12 AM
silverCRXTC
46
Feb 18, 2004 08:24 PM
