who has a h/f in a 91 crx si
Old Jul 13, 2011 | 05:36 PM
lude72's Avatar
Default who has a h/f in a 91 crx si
i need axle info and i'd like to see some pic.
thank you
Old Jul 14, 2011 | 04:43 AM
dephtone's Avatar
Default Re: who has a h/f in a 91 crx si
http://www.explicitspeedperformance.net/ESPEFHF.html
All the info you will ever need for a H swap in an EF.
From the site:
Axle Combo:
88-89 Acura Integra driver side axle off shelf parts store.
90-93 Honda Accord Ex or Lx model midshaft
88-89 Acura Integra passenger side axle that has been cut down 1/2" on the shaft and has an Accord 90+ Inner joint put on it. Raxles.com sells this 1 custom axle. Ask for Marty.
Old Aug 15, 2011 | 12:36 PM
lude72's Avatar
ok guys i did it ...crx with a f22 in it
i had to do some cutting and welding
i had to make the accord shifter fit the crx
i had to cut the front cross member to make room for the cable to hydro conversion
more to come soon
Old Aug 15, 2011 | 01:33 PM
HonduhDave's Avatar
I'm confused as to why you did this, not hating by any means - just curious...of all the motors available to you why would you choose a F22?
Old Aug 15, 2011 | 02:14 PM
lude72's Avatar
in the end it will be a g23 swap ... the f22 is just to work out the bugs...and cheap too
Old Aug 15, 2011 | 03:07 PM
HonduhDave's Avatar
gotcha, that makes way more sense...
Old Aug 15, 2011 | 03:16 PM
lude72's Avatar
we also thought about boosting it to ...again f22 is cheap and with a good tune and h22 head the f22 is a different motor
RSRCliqueCRX
Nov 5, 2012 05:08 PM
A1
Jun 30, 2004 06:23 PM
kron0ne
Dec 16, 2003 10:29 PM
velocitysir
Jun 9, 2002 04:55 PM
