Need help B16A2 into 99 EX
so my y8 got a hole in the block somewhere
RIP.
I'm looking to put a b16a2 into it now, but I need to know everything that I'll need to make a complete swap. The way I see it, being a 99 EX the b16a2 swap should all fit almost perfectly but I need specifics.
Also anyone know where I could buy a complete swap? I think i'd prefer it be a rebuilt engine from a shop than something with a ton of miles on it. Also it has to be an A2, I need to stay smog legal here in CA and i'd prefer it just be from a same generation Si. Thanks ahead of time
RIP.I'm looking to put a b16a2 into it now, but I need to know everything that I'll need to make a complete swap. The way I see it, being a 99 EX the b16a2 swap should all fit almost perfectly but I need specifics.
RIP.
And you will also need an ecu.
HMO? LOL @ $x,xxx amount of money for a stock B16. Where do you live in CA? I will try to help you out as much as I can. I live in N. Cal.
30004 - B16A 92-95 or 96-98 (SiR-II) Motor, Tranny, ECU
170Hp 113Trq 10.4 Compression (JDM)
$ 2150.00 Plus shipping and handling 92-95 Spec
$ 2350.00 Plus shipping and handling 96-98 Spec
30008 - B18C 94-97 (GSR) Motor, Tranny, ECU
180Hp 126Trq 10.6 Compression (JDM)
$ 2699.00 Plus shipping and handling.
You're paying for a motor that won't pass visual on none of these motors unless you find one that is 99-00 compliant. I bet for those two years, they will charge you a few more benjamins too. And you will need to convert to USDM specs for pass Smog/BAR. You will be able to pass smog with a JDM motor but you need to spend more time and money in doing so.
Best bet is to find a cheap used (99-00) B16A2 or better yet a B18C1 and rebuild it to your own power/performance specs. If you get lucky, you may be able to find a low mile USDM complete B16A2 with ECU and wire harness from a total or wreck car. For a complete plug and play.
