fuel pump/srs fuse problem
Old Jul 12, 2011 | 07:31 PM
f22_Strike's Avatar
Default fuel pump/srs fuse problem
ok i have a 98 integra ls obd2
while i was driving my fuel pump stopped working and i couldnt figure out why i looked over the wires and finally looked at the fuse (fuel pump/srs) fuse and it was blow so i put a new one in and tried it worked for a second then blew i did this 2 more times after i rechecked the wires. finally i pulled the SRS unit fuse and put it in the fuel pump/srs fuse and the pump worked with no problems. also idk if this is anything to do with all that but my srs light has been on a while now im going to reset it tomorrow. any ideas how to fix all this?
Old Jul 13, 2011 | 05:50 AM
fcm's Avatar
fcm
Old Fart
Default Re: fuel pump/srs fuse problem
Sounds like the problem is the SRS unit, you may need to replace it. 94
Cordell Raw
Apr 20, 2016 01:23 PM
b16b18
Apr 14, 2008 09:04 AM
