Toy in the A/C
Old Jul 12, 2011 | 07:51 AM
yudhamica17's Avatar
Default Toy in the A/C
hey guys, i have a 2000 civic coupe and the previous owner's kid dropped a toy in the A/C, i dont know how but they did. whenever the A/C runs it starts to crackle and sometimes if you hit a bump it stops, and hit another bump it can continue once more, im getting really tired of it.
is it hard to try to remove the toy by yourself?
or how much is it for a mechanic to do it?
thanks guys really appreciate it
Old Jul 12, 2011 | 08:18 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Toy in the A/C
Where in the vents is it? If it's the 2 outer ones you can pop them off and use a coat hanger or something to fish them out. If it's the inner vents then be prepared to start ripping apart the dash.
Old Jul 12, 2011 | 08:33 AM
dem0nk1d's Avatar
Shop Vac should get it out...
Old Jul 12, 2011 | 08:42 AM
Former User's Avatar
If you remove three screws, the blower motor drops down and out.
Old Jul 12, 2011 | 08:45 AM
motegicivic's Avatar
Ron do you have a diagram to remove the blower?
Old Jul 12, 2011 | 08:47 AM
Old Jul 12, 2011 | 08:54 AM
Thank you Ron, were do you look under the dash to see it?
Also, I assume it has a molex type connector?
Old Jul 12, 2011 | 08:57 AM
Look up from below the glove box to see the blower motor and its screws. Run of the mill connector.
Old Jul 12, 2011 | 01:29 PM
its the outer vents, so ur saying its as easy as popping off the cover and using some close hanger?
is it really that easy?
Old Jul 12, 2011 | 01:46 PM
dem0nk1d's Avatar
taking vents out can be tricky sometimes. i use the buttends of a butter knife. usually works for me, or get a set of plastic pry tools. because plastic on plastic doesn't usually mar the other part.
take your time
johnny hatchback
Feb 13, 2005 02:48 PM
rasinhell
Jan 14, 2005 07:47 PM
Kicklow
May 22, 2004 12:23 PM
deftones0817
10
Mar 7, 2004 05:57 AM
Richard.
Audio / Security / Video
May 28, 2003 12:55 AM
