F/S K series Race parts need gone ASAP!
Old Jul 12, 2011 | 06:54 AM
k24egturbo's Avatar
Default F/S K series Race parts need gone ASAP!
Im parting out my K-Series EG project car. All prices do not include PAY PAL FEES or SHIPPING
Located: Central NJ
NEW ITEMS ADDED!!
SOLD! USED AFI Intake Manifold W/ 90mm Accufab TB (comes with all sensors and Throttle cable bracket)
$260 USED RC550CC Injectors ( purchased from a vendor on here, there were sent to RC to be flow tested by vendor and i haven't used them)
$220 Both Axles & Mid Shaft from a Type S
$1400 02-04 Type S transmission: OBX LSD, new oem bearings, new second gear set, new synchros. (haven't been used after rebuild)
SOLD! Karcepts K20a/a2/z1 AC and PS Removal Kit PN# KPS01
SOLD! Aeromotive A1000 PN 13101 Fuel Pressure regulator W/ Gauge and fittings (10an plug, 10an feed, and 8an return) like new.
SOLD!NIB AEM 25-111BK High volume Fuel Rail Black
$140 New Denso Primary oxygen sensor
SOLD! Hybrid Conversion Harness for EG/DC was installed in track car for a few week, Like new
SOLD! PRB 02-04 ECU
SOLD! USED Karcepts shifter kit, Type S shifter box and shifter cables
SOLD!USED Hasport EG/DC engine mounts (a few scratches)
SOLD! Earls steel braided clutch line
$380 NIB ACT Clutch Kit AR1-HDR6
$70 Resurfaced Type S fly wheel
$500 Used Competition twin disk clutch( was on one of our track cars, the fly wheel bolts backed out a little and caused the fly wheel rattle against the crank. fly wheel needs to be machines smooth where the bolts holes are, clutch is still in working order and only has a few miles)
SOLD! CR-V passenger side bracket w/ Bolts
$90 for AFI, Xcessive, IPS style intake manifold Center Throttle body intake Kit (4FT of 4" aluminum piping, 4" Black blox velocity stack, 4" 90 Deg coupler, 3 3/4"-4" coupler, 4" straight coupler)
SOLD! 3" Thermal Exhaust system W/ 3" hi flow cat and clamps
$350 4" Turbo exhaust W/ Burns muffler
$70 5FT of 4" Stainless steel exhaust piping
$60 Silver Auto-meter Tac w/ shift light new but box is open
$60 Sunpro Tac w/ shift light NIB
$950 SSR/DTR K24 4-1 Race Headers W/ mega phone and V-band clamp
SOLD! EP3 Pully W/ Bracket
$55 Type S starter
$70 Type S Alternator
$280 Type S Manifold, Injectors, Fuel rail, TB(missing cable bracket)
SOLD! AEM 30-4100 Wide Band Air/Fuel UEGO Gauge used for a week
$180 AEM Tru-Boost electronic Gauge Type Controller 30-4350 used for a week
$110 AEM 5 BAR external Sensor upgrade Kit
SOLD! 02-04 charge harness uncut
SOLD! 02-04 charge harness already modified for k swap car
$35 Type S throttle cable 2 available
$85 15FT 8an Russell ProClassic Hose
SOLD! 8 new OEM fly wheel bolts
SOLD! 6 new OEM pressure plate Bolts
$30 Camshaft Sensor Type S 2 available
$40 Skunk 2 5 speed Shifter ****
$20 180 degree 10an fitting
$8/each 4an turbo feed fitting/ 10an return w/ male fitting/ 8an return w/ female fitting
$9/each Mr gasket straight 8an fitting 4 available
$10/each Russell straight 10an fitting 2 available
$7/each 10an thread plug/ 2 8an thread plug
$20 NGK plugs IZFRGK11 qty 4
$120 Dual core radiator w/ slim fan
$70 HI Power slim fan used only on dyno paid $100 from summit racing
$150 Seats front and back, They are really clean as you can tell from the pictures
Old Jul 16, 2011 | 02:25 PM
k24egturbo's Avatar
Default Re: F/S K series Race parts need gone ASAP!
BUMP TTTTTTT
B20vEf9
Mid-Atlantic (Sales)
11
Feb 7, 2012 06:22 PM
B20vEf9
Northeast (Sales)
13
Feb 7, 2012 06:21 PM
DEL HATCH
Jun 28, 2009 08:36 PM
