Ek civic h22a swap issues
Old Jul 11, 2011 | 06:05 PM
RdmptionCivic's Avatar
Default Ek civic h22a swap issues
So I just got a h22a swapped ek.
When you push in the clutch it dies, so you have to be rather quick on the clutch.
I've had one friend say wiring, and another say something about washers, and a thrust bearing.
I was just wondering what anyone thought it might be.
Cuz this car is also slow as *****, and I think that has to do with it having crappy wiring, and whatever else sapping its power.
Thanks in advance.
Old Jul 11, 2011 | 08:24 PM
that_boy_sammy's Avatar
Default Re: Ek civic h22a swap issues
Could be bad a thrust bearing. Maybe its just a bunch of dirty components like your iacv, throttle body, injectors, fuel filter,fuel pump, bad tps,bad slave cylinder, bad master cylinder. Start by cleaning the IACV though im pretty sure its clogged badly. Are you throwing any check engine codes?
Old Jul 12, 2011 | 06:36 AM
I know I'm throwing a check engine light, but I haven't seen which code yet.
And one of my friends who was a previous owner said it that he checked the thrust bearing, because if it was then the crank pulley would move.
Old Jul 12, 2011 | 08:41 AM
Clean your IACV for sure though.
KYBr00ks345
Jun 4, 2019 07:31 PM
Keir Gale
Mar 11, 2018 10:30 AM
cleanazcoupe
May 28, 2012 11:47 AM
wbb6
Apr 9, 2002 05:11 PM
