HELP - Need Honda Bolt
Old Jul 11, 2011 | 05:45 PM
gearheadauto's Avatar
Default HELP - Need Honda Bolt
I'm in search of a bolt for I believe a 90-97 honda accord. The bolt in question is one of the four bolts that hold the front hub/bearing to the steering knuckle. these four bolts run through the backside of the knuckle and into the hub. They're 10mm -1.25 thread and have a 12mm head. Anyone in Austin Texas or the Austin Area please let me know as soon as possible if you have any of these bolts or one of these cars that you're parting out. I really appreciate everyone's time. Thank you.
Old Jul 11, 2011 | 06:13 PM
SQ is the SQUAD's Avatar
Default Re: HELP - Need Honda Bolt
i have some of those. pm me your address ill mail you one.
check out my build thread, i just did mt wheel bearings/5lug swap. had a few spares of those bolts
Old Jul 11, 2011 | 06:44 PM
jamzx3's Avatar
honda dealer should be really cheap...i got that big brake caliper bolt for .94 from my hondadealer
Old Jul 11, 2011 | 07:31 PM
specialone70's Avatar
you could try your local ACE hardware
Old Jul 11, 2011 | 08:29 PM
Nicefeet's Avatar
It's a special bolt with a tiny 12 point head designed to clear the CV joint.
I would hit up the local pick-n-pull and pick up a few
Old Jul 12, 2011 | 04:23 AM
djkurious's Avatar
The local JY would be your best bet!
StreetRacinThug
Jul 30, 2011 12:03 AM
cedrichawkda6
Suspension & Brakes
Aug 3, 2010 09:30 AM
wickedEFguy
May 25, 2010 05:39 AM
KFMRC
Honda S2000
May 18, 2006 11:08 AM
Sleepy86o
Nov 10, 2005 03:52 AM
