are automatic and standard from torque mounts the same?
converting from auto to 5 spd. my 5spd parts car the front toruque mount was ripped. the original auto one is still good. any differences in the mounts?
either way its getting poly filled, just seeing if anyone had any general knowledge about this
Don't believe there is any difference in the Torque Arm front engine mount. the rear engine mounts are different between AT's and Manuals.Which you probably already know.
i have the 5spde bracket and mount, its just the mount itself is towrd to ****. i need to try to use the auto mount.
hopefully by Christmas i can get some esp traction bars.
Is this mount going in the 95 Wagon? As the 94 and up don't use the Torque Arms they in my opinion use a better mount than those torque arms.
94 & 96's use the same front engine mount they just don't use those Dog Bone style Torque Arms. Should be no problems. Good luck to you and your build, I have been following your build thread as I drive a 4th gen wagon.
kd97accord
Apr 29, 2010 05:06 PM
mingbling96
Mar 12, 2005 01:12 PM
