Koni Sport Shock 8041-1152Sport Honda Civic, Del Sol, Acura Integra
Old Jul 11, 2011 | 03:38 PM
raticosa's Avatar
Default Koni Sport Shock 8041-1152Sport Honda Civic, Del Sol, Acura Integra
Koni Sport shock part number 8041-1152Sport to fit the following cars:
92-95 Honda Civic except wagon Front
96-00 Honda Civic except wagon Front
92-97 Honda Del Sol Front
94-01 Acura Integra Sedan Coupe except Type R Front
97-01 Acura Integra Type R Front
It has an adjustable spring perch and is capable of lowering the front by 25mm or about an inch. this shock is used but appears to be in great condition. the piston rod extends on its own (do NOT buy a high pressure gas koni whose piston rod stays compressed on its own.) and the movement is smooth throughout its travel. also, there is no evidence of any oil leakage at all. this shock is adjustable for rebound by turning the top adjustment valve. and it is a sport shock so it is stiffer than than the standard shock and also is intended for lowered applications. there is some damage to the outer housing as pictured but as i've already stated, the shock compresses completely with no problems.
great as a spare or buy this one and get the other new and save a bunch. these sell for around $140 and up for each shock. buy it here for much less. i have no use for this and just accumulated it along my car travels rather than see it go to waste. i'm a car freak but my tastes run to european cars such as porsches, vw's and alfa romeos so i wish this fit one of my cars...
oh, and let's say $75 shipped in the CONUS or $60 picked up. i'm in LA (hollywood area).
comes with bump stop, adjustable spring perch and circlip which holds spring perch.
cheers, bob
AND PLEASE NOTE THAT I ONLY HAVE THE ONE SHOCK.
Old Jul 13, 2011 | 10:58 PM
raticosa's Avatar
Default Re: Koni Sport Shock 8041-1152Sport Honda Civic, Del Sol, Acura Integra
bump
Old Jul 19, 2011 | 08:48 PM
raticosa's Avatar
bump it and use my shock to dampen it
Old Jul 23, 2011 | 12:49 AM
raticosa's Avatar
bumppppp
Rez93del
Suspension & Brakes
Jun 30, 2019 03:51 AM
trm4life
Apr 9, 2017 09:02 PM
cdizzle
May 7, 2006 05:27 PM
