Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Back tires bigger than the front?
Old Jul 11, 2011 | 01:51 PM
helloimD4NNY's Avatar
Default Back tires bigger than the front?
I found some white ls meshes on craigslist. I asked the guy for the size of the tires that come / w the meshes and he said that he doesn't know at the moment but he will check later. All he knows is that the back tires are bigger than the front.
My question to you is that if I put those on my 02 Civic EX Coupe, will there be any problems that i'll come across? Also if theres problems w/ his tires, could I put the meshes on my current tires? They're the tires that came w/ my steelies from the dealership. They're 195/60R15.
Old Jul 11, 2011 | 01:55 PM
civichxtreme2's Avatar
Default Re: Back tires bigger than the front?
You could put them on there as long as you make sure you run the same size on both rears and same size on both fronts. Wouldnt cause any problems really. If its only one size off you may not even be able to tell. You could also use your stockers, those would fit LS mesh Wheels not problem, Thats what I run on mine
Old Jul 11, 2011 | 02:10 PM
How do your meshes look on your stock tires? I think my tires look thick af right now. Lol.
Old Jul 11, 2011 | 02:41 PM
Harlowe's Avatar
Function>Fashion
no it will be fine. i've ran a few staggered/reverse staggered setups.
Old Jul 12, 2011 | 06:54 AM
wittynamessuck's Avatar
You wont have any problems except rotating them. I have run staggered on both FWD and RWD.
Old Jul 15, 2011 | 06:26 PM
sdaidoji's Avatar
if you have ABS, depending on the difference on OD, ABS module could go crazy due to RPM difference. mine threw ABS light as soon as a mile using a 205/50R16 in conjunction with 205/55R16
Old Jul 15, 2011 | 11:18 PM
lazlong's Avatar
Ran 225/45/R17 in the front and 215/55/R17 in the rear for awhile (don't ask) with no problems besides a camber kit and fender rolls.
Old Jul 16, 2011 | 10:40 AM
They didnt really look too bad, Im lowered about 2inch MOL but They filled the well up nice and didnt look too terrible either, the did rub a bit on larger bumps, thats the only downside
andymacEK9
15
May 17, 2010 07:48 PM
jrom
Honda Civic (2006 - 2015)
Aug 28, 2007 11:26 AM
uscg-bm
Jul 12, 2007 09:56 AM
G3NR8
Mar 9, 2005 05:48 AM
