valve cover HELP!!!!!!
Old Jul 11, 2011 | 12:06 PM
EK squid's Avatar
Icon6 valve cover HELP!!!!!!
i over tight the left back bolt for my d16 n the bolt broke what should i do??? could i retread the hole r is my block ****ed???? plz HELP!!!!!
Old Jul 11, 2011 | 03:40 PM
pwebb0207's Avatar
Default Re: valve cover HELP!!!!!!
pull off the valve cover. you should be able to easily take out whats left of the bolt as there will be no tension on the threads.
Old Jul 11, 2011 | 05:21 PM
EK squid's Avatar
its broken off half way in the hole
Old Jul 11, 2011 | 05:26 PM
HNDA_4SHOOR's Avatar
Dealership has special tool to drill it out
Old Jul 11, 2011 | 05:33 PM
EK squid's Avatar
Icon2 Re: valve cover HELP!!!!!!
could i buy it r do i have to go there n ask them to take it out???
Old Jul 11, 2011 | 06:47 PM
I would pay for them to do it. It could take a while depending on location of the broken bolt and if you mess it up, might lead into bigger problem
Old Jul 11, 2011 | 07:55 PM
CivicBlacksheep's Avatar
10 Year Member
Reversable drill bit...pb blaster....if u get it right, the bolt will back itself out
Old Jul 11, 2011 | 09:16 PM
pwebb0207's Avatar
take a small flat head screw driver that will fit down in there and try to back it out.
Old Jul 11, 2011 | 09:24 PM
EJ1_CRIS_909's Avatar
Extractor drill bits will pull it out.... Get a drill bit that will neatly drill a hole into the top of the broken bolt without threading too wide, get the extractor that fits into the hole, and itll pull it right out.
Old Jul 11, 2011 | 09:34 PM
Wrona's Avatar
valvecover doesnt thread into ur block just satin
Old Jul 12, 2011 | 04:47 AM
FrankJones's Avatar
Good luck!
Old Jul 12, 2011 | 05:06 AM
4dohs4mohoes's Avatar
It's reall hard to read what you're saying when all the letters on your keyboard don't work.
Take it to someone who actually knows what they're doing.
Old Jul 12, 2011 | 09:36 AM
that_boy_sammy's Avatar
ez-out
Old Jul 12, 2011 | 07:42 PM
EK squid's Avatar
welll i got it rigged n the cover is been held down by the other four bolts it seems to be workin fine goes into vtec to so i guess i a save up n go to a B
Old Jul 12, 2011 | 08:03 PM
SeanK325's Avatar
Are you trying to say that you somehow have the bolts from the cover going down to the block? What the hell is going on?
Old Jul 13, 2011 | 04:10 AM
Hahaha!
Old Jul 13, 2011 | 04:38 PM
Originally Posted by 4dohs4mohoes
Hahaha!
+1
Old Jul 13, 2011 | 05:17 PM
xero_xero's Avatar
where are you located?
Old Jul 13, 2011 | 08:59 PM
EK squid's Avatar
lol no i didnt say that. I tighten the other four bolts for the cover a lil harder than u should n i plugged up the hole for the bolt that had got broken
deebo's ek9
10
Sep 30, 2010 10:01 PM
00ekcoupe
37
Sep 5, 2005 06:15 PM
renzema
Aug 29, 2005 09:42 AM
happy_guy
Aug 9, 2005 06:36 PM
::mebri::
May 18, 2003 06:57 PM
