( Pic inside ) Broke this piece on my Ys1 Tranny, Ideas?
Old Jul 10, 2011 | 11:36 PM
93grayeg's Avatar
Default ( Pic inside ) Broke this piece on my Ys1 Tranny, Ideas?
Hey guys this piece snapped off my ls cable transmission , I have know idea what to do or how to fix this, Do i need to get a whole new transmission? This is where the cable sits in . Any idea if I could fab something up and have it welded?
Old Jul 11, 2011 | 01:00 AM
crx_si-r's Avatar
Default Re: ( Pic inside ) Broke this piece on my Ys1 Tranny, Ideas?
just pull one off another LS cable trans, not sure if D-Series cable trans are the same, and your good to go.
Old Jul 11, 2011 | 03:14 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
If you have to ask if you can fab something to work then you are better off just getting a direct replacement part.
Old Jul 11, 2011 | 09:14 AM
93grayeg's Avatar
Does this piece bolt on from inside the tranny? Or am i going to have to pull the tranny out
Old Jul 11, 2011 | 09:55 AM
Clipsed's Avatar
You have to pull the trans to replace it.
Old Jul 11, 2011 | 09:57 AM
93grayeg's Avatar
that's what I was afraid of. Do you think something could be fabbed up to make to work? it just snapped the little hook piece
Old Jul 11, 2011 | 10:06 AM
Clipsed's Avatar
probably, but that wouldn't be my first choice to do because I don't like to half *** ****...
Old Jul 11, 2011 | 12:37 PM
tonylovesjdmEF9's Avatar
neverever do half as **** on your ef plz i have to deal with half *** **** due to the ex owner of my ef its a pita bro take the trans of its only 12 bolts or so n replace it
Old Jul 11, 2011 | 12:53 PM
Kimmers56's Avatar
I agree, replace it. The crank shaft bolt broke on my engine and I could of easily half assed it, I just did a swap on it to avoid any future issues.
Old Jul 11, 2011 | 08:40 PM
MISTAGLOCK's Avatar
you CANT custom "fab" something there that hook eye is for the tip end of the clutch cable and from workin on a B18C with a cable tranny you gotta pull them bastards hard to enguage the clutch. i can see u "fabbing" something on there and when u go to press in the clutch *loud snap* and your clutch is no longer functional....... i doubt you can do extreme damage if you "do fab something up" but how did u break it in the first place. thats a sturdy piece of metal! maybe be careful next time?
Old Jul 11, 2011 | 09:12 PM
VtecSyndrome's Avatar
Even if you or someone you know had the skills to weld up a new tab on the end of this (about the only way to repair right) you would still likely have to remove it from the trans to make sure it's done right.
Just pull the trans out, it's not that hard. It's been a while since I removed the shaft release but I do think it can come out with out actually having to break the trans case open.
heres the dealer pic from acura for a '92 integra LS shaft release
http://www.acuraautomotiveparts.org/...s=&view=normal
It's only $30 list from Acura so it really is better to just buy a new one
Old Jul 11, 2011 | 09:50 PM
93grayeg's Avatar
http://www.acuraautomotiveparts.org/...s=&view=normal. Thanks for the info man , the guy that builds my dads race cars said he could weld something up to fix it but I didn't know that part was still for sale through Acura , thanks
Old Jul 12, 2011 | 02:59 AM
vtecn8ive's Avatar
Yup just the one bolt. But sometimes they can be a little tough to get out.
Old Jul 12, 2011 | 07:36 AM
yea, it CAN seem like it won't come out some times after the bolt is removed. you just gotta work it back and forth til it breaks free.
90ED6LSV
Nov 1, 2011 01:08 PM
nycpatron
Transmission & Drivetrain
Feb 8, 2010 05:03 PM
pinecone
Apr 12, 2006 01:26 PM
Dumped DB2
Apr 11, 2004 11:46 PM
Digitalcivic
Dec 24, 2002 08:54 AM
