bad IAC sensor??
so i have a jdm b16a SiRII that had a itr intake manifold on it... i replaced the mani gasket and cracked the itr manifold and had to get a stock b16 one from my friend. it doesnt have any place to plug in the intake air temp sensor (IAT) so i dont have that in and thus im throwing a code. my problem is that when i let the clutch out and give it some gas i get a quick surging idle until i ride the clutch a little bit. I am using the idle air control valve that came with the stock b16 mani. could that sensor be bad thus causing my surging idle?? and can i put the IAC from my itr manifold onto the b16 manifold to see if thats the problem??
Thanks in advance!
Thanks in advance!
You can find one of those sensors for under $20. Fix that cel and it might fix your problem. Also it doesn't hurt to try and swap the iacv, it will most likely fit.
i plan on getting the crack in my itr manifold welded by friends hook up who is a professional welder. The itr mani has a spot for the Idle Air Temp sensor but the b16 mani doesnt.... and i will try putting the IAC off the itr onto the b16
It's probably a manifold from a B16A2 if it doesn't have provisions for an IAT sensor. The IAT sensor for the B16A2 is located on the intake pipe a few inches from the throttle body inlet.
I am unsure if you can use the OBD2 IAT sensor with an OBD1 engine. I am positive the connectors are different.
Pretty sure you can use the Type R's IACV with the B16. Maybe someone else can confirm this.
awesome thanks! and i have a whale ***** intake so could i maybe put the IAT in the intake? and like i said i plan on putting my itr one back on but this is just to get m,y car running. and i do believe that the b16 mani is off of a a2. my b16 is an A.
da_ska
11
Aug 6, 2008 02:33 PM
I Like Hondas
Jun 22, 2008 02:59 PM
Phaze2 Mike
Dec 31, 2003 06:20 AM
