Anyway to upgrade an older sc61
Old Jul 10, 2011 | 11:06 AM
boostedb20z's Avatar
Default Anyway to upgrade an older sc61
I have an sc61 on my car now at 30psi and it has the small .63 exhaust housing on it now. this winter i plan on going to the .82 for more flow but im wanting to know if theres a race cover or a better comp housing that would help the 35r wheel thats inside that small .60 e-cover. thanks
Old Jul 10, 2011 | 12:58 PM
TheShodan's Avatar
Moderator
Default Re: Anyway to upgrade an older sc61
Check with Lighteningteg on H-T. He did an SC61 upgrade. Going simply to a larger A/R may not work if its still using the smaller stage 3 wheel. The difference in power deliver between the .60 E-cover and .70 S-cover for that wheel is rather minimal; its the change in compressor wheel and turbine wheel that need the change up. Something lighteningteg did.
Old Jul 10, 2011 | 02:54 PM
thank you ill shoot him a pm
Old Jul 10, 2011 | 04:03 PM
Gunmetal_B20_Hatch's Avatar
Just curious, but how much power were you able to make on the .63 housing @ 30psi? Thanks!
Old Jul 10, 2011 | 07:36 PM
not a whole lot but we think its in the ls head that i port matched to a hondata gasket
Old Jul 10, 2011 | 07:51 PM
LightningTeg's Avatar
Community Builder
I had Mac put a 62mm Reaper billet wheel on my old SC61 when it needed a rebuild. Spools about 500 rpm sooner then the SC61 cast wheel and makes at least the same amount of power at the worst. But I have not tested its potential
I made 513 @ 30psi with that upgrade on pump gas, stock LS head with 404 cams.
Old Jul 10, 2011 | 08:38 PM
did you just drop your cams in or did you degree them in (if so what are you gears set at)ive heard mixed things i have the 404s too and at 30psi its only making 377whp (this was on a mustang dyno if that matters) and we are trying to find out whats going on havent tried a differnet dyno yet many people say it could be the .63 exhaust housing but i dont really think it would hold that much back.
We've had the car out twice to the local 1/8th mile best time has been 7.3 at 102mph and we are spinning 1st at 2nd still 60s are high to 1.6-1.7
heres the setup
Bottom End:
B18A1 block stock bore and sleeves
SRP pistons 81mm 10.7.1 comp
.74 head gasket
Eagle Rods
ACL Race bearings
moroso oil pan
Head:
B18A1 head port matched
BC dual valve springs and ti retainers
Crower 404 all motor cams
Edelbrock intake manifold
hondata intake manifold gasket
moroso valve cover
Tranny:
GSR with OBX diff
Stock alxes lol
Turbo setup:
750hp intercooler
SC61
Spa Topmount
50mm BOV
38mm Wastegate
Chassis:
sk2 coil overs if front but used the sk2 sleeves in back on 18k springs
8 point cage
24.5x8x13" slicks
Fuel setup:
A1000 pump
sumped tank
2 earls filters one 100 microns and the other 10
-8 to pump and -6 everything else
aeromotive fpr
BDL fuel rail
ID 1000cc
Steeve_Civic
Dec 20, 2011 10:25 PM
xero_xero
May 4, 2010 08:05 PM
seen4ever
Jul 1, 2006 03:17 PM
Quick 200k Mile Motor
Jun 13, 2003 11:03 AM
