At Clutch pressure solenoid re-install issue 99 accord ex v6
I have a 99 accord ex v six. I removed and cleaned and tested the the lockup A and B solenoid and screens. The C and D solenoids. On the Clutch Pressure Solenoid. When removing I pulled out the three tubes and o rings that go through the gasket. I did not look at the orientation of the tubes when I did this. On one end of the steel tubes they have a type of flare on the other end of the tube they are slightly tapered. Does anyone know which end of the tubes go up into the solenoid body and which goes down into the tranny body
