My final slick question (I promise lol)
Old Jul 9, 2011 | 10:08 PM
guy_from_nerk's Avatar
Default My final slick question (I promise lol)
NVM found my answer please delete
Old Jul 9, 2011 | 10:19 PM
theidealone's Avatar
Default Re: My final slick question (I promise lol)
Well, here's my gathering...
You dont want to put wheel screws into the slicks with tubes. Or at least I wouldnt. Tubes are expensive as ****, and if a screw put a hole in one (which is shouldnt if its the right length), that would SUCK!!!
If you dont run tubes, they will most likely leak. Some faster than others. I have Bogarts, which are guaranteed not to leak. My M/Ts did leak, but with the M&Hs, they dont. Well, they might leak a few PSI over a couple of weeks time. But not enough to worry me at all. They are designed to be run with tubes, but not completely necessary. MOST racers I know, import or domestic, dont run tubes.
The only reason you might want to beadlock, is so you can keep the tire from slipping on the rim. But the biggest reason I can see, that you dont want it to slip, is so that you can balance the wheel/tire. Otherwise, they only slip like 1/4" a pass usually. Not enough to do anything.
Mine arent balanced, the tires slip (I cant bring myself to drill into my nice Bogarts), and I cant feel any shake or vibration at the track.
Hope that helps.
JakeSpec
Dec 2, 2010 09:29 PM
Felliph3
Feb 23, 2007 04:07 AM
ujhonda
Nov 17, 2005 07:44 PM
Dave01
Mar 20, 2004 02:06 PM
964dgsr
Feb 19, 2003 06:49 PM
