K20CRX swap
Hey ht, im from Brunei. My brother had an ep3 type r and was in an accident, it cost so much to put everything back to the way it was, so we plan to swap everything from the ep to my crx like brakes, engine, seats etc. Im planning to use hasport mounts (which does not fit perfectly on JDM models) and hybrid racing shifter and cables. Planning to tackle most of it by ourselves.
I have read about people swap k20 to their crx and using them as a guide.
My only question is.
How can i fit the Ep3 brakes with the spindles and driveshaft to the crx,will it work? if not, what will i need to make it fit?
Thanks in advance.
I have read about people swap k20 to their crx and using them as a guide.My only question is.
Thanks in advance.
putting the spindles from a ep on a crx will not work there might be a way to mount just the caliper and rotor if the rotor is 4 lug or you already have 5 lug conversion, the axles can be used but you will have to change the outside with the stock crx ones
