car wont stay running help
Old Jul 9, 2011 | 08:53 PM
cincyb20ek's Avatar
Default car wont stay running help
ok i got a b20vtec that ive built this past winter and i have it in the car and i am having trouble with it starting and staying running. heres the run down... b20b block b16 head gsr trans cp 11.5;1 pistons eagle rods all super tech valve train skunk 2 cams intake manifold 450cc blue top injectors. neptune base tuning software. i have a resistor box on there and on the fourth cylinder the injector is having continuous power. im gonna get another one tomorrow. i have went threw and make sure i had good connections for the grounds. any suggestions what could keep it from running?
Old Jul 10, 2011 | 07:29 AM
fcm's Avatar
fcm
Old Fart
Default Re: car wont stay running help
Not sure I understand, "on the fourth cylinder the injector is having continuous power".
The injectors are supposed to have "continuous" power as long as ign. switch is on, the injector is "fired" buy a ground pulse from the ECU/ECM.
If you mean the injector is on all the time, [flooding cylinder 4] the problem is the ECU/ECM or the injector lead from the ECU/ECM to injector 4 is "shorted" to ground 94
Old Jul 10, 2011 | 09:35 AM
cincyb20ek's Avatar
whats ground 94?
Old Jul 10, 2011 | 10:10 AM
fcm's Avatar
fcm
Old Fart
Originally Posted by cincyb20ek
whats ground 94?
Ignore the 94, ground= 12V-, [neg.(-)] the ECU/ECM supplies a ground pulse to trigger the injectors. 94
94= me saying ten four. 94
lsvtek
15
Jul 10, 2012 02:28 PM
turboek03
May 15, 2011 07:32 PM
TwoKSiR
Sep 23, 2010 06:09 PM
92rotteneg
Feb 8, 2010 04:02 PM
mickey b16
May 26, 2009 04:02 PM
