D4 Light on Tranny Selector Doesn't Light
Old Jul 9, 2011 | 05:44 PM
zrsm9's Avatar
Default D4 Light on Tranny Selector Doesn't Light
The D4 light for the tranny selector on the dash of my 92 Accord (204,000 miles) doesn't come on when putting the tranny into gear. All other indicators light up depending on the gear.
Also, the car is developing a hard shift from 1st to 2nd depending on how hard you accelerate. If you put your foot in it, the car will shudder. Tranny fluid has been changed supplied by Honda, no change. The fluid that came out was burn't and not bright red.
Any ideas?
Thanks,
Richard
Old Jul 10, 2011 | 06:35 AM
poorman212's Avatar
Default Re: D4 Light on Tranny Selector Doesn't Light
Replace the bulb, then check for codes.
No TCU Codes, Check mounts, throttle control cable. If the fluid was that bad, I'd also suggest one or two more drain and fills of the trans.
Old Jul 11, 2011 | 05:59 PM
Jmb106jr's Avatar
Any ideas?
Thanks,
Richard
Check to see if the the D4 lights for 2 seconds like the CEL does at start up, this will tell you if the bulb is burnt out. I am leaning towards the Gear Position Selector Switch, which could be faulty. How many drain and fills did you do w/ the new Honda fluid? As stated above you may need to do a couple more drain and fills w/ the new fluid. It may take some time for the new fluid to leach into the clutch packs and give a better shift feel or it may never change due to what sound like an over extended trans fluid change interval.
Old Jul 11, 2011 | 06:43 PM
nicolaselias's Avatar
Loved
Community Favorite
Similar problem with mine.. I think its just the bulb gone.. All the other bulbs work, I have no codes and no transmission problems that I can detect..
Not worth my trouble of taking out the cluster just to change the bulb either.. If its not lit, then im in D4, simple as that..
Old Jul 12, 2011 | 10:53 AM
William1991b's Avatar
opend cluster and change the bulb from 1 2 or D3 into D4 thats wat i did and it works i dnt use the others so dnt matter to me or u can buy one for 5$ and shipping 12$
Old Dec 18, 2019 | 07:42 PM
Steve Jabs's Avatar
Any ideas?
Thanks,
Richard
Did you ever figure it out I recently acquired a 2002 LX same exact issue and cruise doesn't work switch and dash light up. Thanks
Old Dec 20, 2019 | 12:34 AM
MAD_MIKE's Avatar
MM Gruppe B
Originally Posted by Steve Jabs
Did you ever figure it out I recently acquired a 2002 LX....
Different trans with different nuances.
Best to beg/borrow/steal a OBDII code reader and check for any stored codes.
prelewdracer
Aug 14, 2010 06:48 AM
revvin9k
Honda S2000
Oct 9, 2005 05:29 PM
PharmSC
Jul 31, 2005 01:08 AM
jdmsteve2004
May 24, 2004 08:29 AM
hankd
Jun 20, 2003 06:04 AM
