Brake Check valve question.
Old Jul 9, 2011 | 01:10 PM
Mad-Mike's Avatar
Default Brake Check valve question.
I got a hatch that has upgraded brakes and brake booster(from an integra). The Check valve is bad and I have a brake booster line from another car. Can I eliminate the check valve and run the other vacuum line?
Old Jul 9, 2011 | 01:16 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Brake Check valve question.
Why don't you just get a working check valve? It's there for a reason.
Old Jul 9, 2011 | 01:28 PM
Mad-Mike's Avatar
I probably will get a new one, just was wondering.
Old Jul 9, 2011 | 05:22 PM
apexi_rsx's Avatar
without the check valve the booster will not work correctly. it is what assist the booster to work when u let off the gas and the engine goes to vacuum. it helps pull the pedal down and assist u to brake .
acarguy
Honda Fit
Aug 6, 2017 02:56 PM
90civicstdgold
Mar 10, 2010 12:43 PM
djnikko
Feb 6, 2010 10:43 AM
85mm LS VTEC
Mar 31, 2007 07:57 PM
em1 Ziggy
Apr 17, 2006 04:08 AM
