B18c Type-R JDM Motor/Fire Cut When Impact on Road
Old Jul 9, 2011 | 11:37 AM
fivestarz's Avatar
Icon2 B18c Type-R JDM Motor/Fire Cut When Impact on Road
Hi,
I have a question and maybe some of you may help me.
I have a B18c Type-R JDM on my 96 civic. ECU is chipped, Air Intake, Headers & Exhaust. I also have a dropped suspension.
The problem i have now is when i am on the road with the car and run over a hole in the street or anything that cause a solid impact, the fire cut. The revolution go from 3-4000 to 0. Sometime when i push the clutch he comeback to 900rpm. Sometime he doesn't go back to 900 and stall. I can restart it without any problem.
I changed the air filter and the sparkplugs this morning. The battery ground looks good and is solid but i still have the problem.
I wonder if it's the engine supports or maybe too stiff suspension?
If you have any idea what that can be, please let me know
Thank you verry much,
Sam
Old Jul 9, 2011 | 02:21 PM
civickiller's Avatar
Default Re: B18c Type-R JDM Motor/Fire Cut When Impact on Road
sounds like a lose connection somewhere. i never ran into this problem before
Old Jul 9, 2011 | 02:40 PM
grumblemarc's Avatar
The Grumpiest
Loose ground would be my guess.
Old Aug 1, 2011 | 07:49 AM
fivestarz's Avatar
thanks guys i will check this out. 250$ of stock and the problem still persist... im about to put the ****ing type r into a treeee!!!
Old Aug 3, 2011 | 03:40 AM
kid6061's Avatar
Check your plug wires and grounds, it sounds like a ignition/continuity problem.
I had a similar problem. I installed a msd cap/ wire combo and amplifier and the same thing happened to me when I would hit a bump. Engine would sputter and come back. It turned out to be the wire from the cap to the amp was not completely seated on the cap. I seated it securely/properly and it went away. Hope you figure it out - good luck.
integraLB1S
Apr 17, 2007 09:34 PM
