dohc zc
No.
If it's all apart why leave the weak factory rods in?
What will your static comp be? What you should really worry and plan on vs comp for your rods is what is your max rpm going to be?
only 20 over,acid dipped, and crank,resurfaced and polished.new p29 nippon racing pistons,with rings. stock rods, king bearings,and new wrist pins.
all the rest is stock...
stock pm7 ecu
stock intake an so forth....
