can somone tell me what this is?
thanks for the quick reply.
how much do you think it will cost to fix this?
how dangerous is it to drive like this?
what parts do i need to buy just a tie rod? are there 2 tie rods or is it one piece?
thank you
thank you
Stop driving the car. It's unsafe to drive. Have it towed to a shop for repair. As for cost, call shops for estimates. Tell them that the rack end/inner tie rod has snapped.
Wow, that's the worst broken tie rod end I've seen. Do you do the regular maintanence on your car or does a shop? How come that wasn't caught along time ago if inspections were done.
To inspect them in the future, when you lift the front end, put your hands at 12 and 6 oclock, and push on the top and pull on the bottom a couple times, take noice of any clunks or looseness.
Then put your hands at 6 and 3 oclock, shake tire back and forth, take note of any looseness.
-If there's the same amount of movement in both top to bottom and side to side, you have a bad wheel bearing
-If you only have movement top to bottom, then suspect a ball joint
-If you only have movement side to side, then start looking at inner and outter tie rod ends.
Built B18ABorC
Sep 22, 2004 06:55 PM
