cbr f3 problem
Old Jul 8, 2011 | 05:29 PM
sdots24's Avatar
Default cbr f3 problem
i own a 1998 cbr600 and im having a problem with the charging system. (of course)
im going to make this least painfull as possible.
-Bike kept dying, thought battery was bad.
-Replaced battery to have it die on me again.
-Clearly not charging battery.
-Checked rectifier regulator to find out its melted and broken to say the least, replaced with new one.
-Connector did not fit so i just bypassed the connector and put the cables on directly to the R/R.
-I forgot to disconnect the battery before i started and accidently hit the power and ground and got a small spark.
-Hooked up r/r and now when i turn the key i do not get any electric at all.
-I checked fuse box in front right near handle bars and all fuses are good.
-I heard there is a main fuse close to battery i will check that tomorrow any other ideas???????
Old Jul 8, 2011 | 10:28 PM
slomofo's Avatar
GDD Member
Default Re: cbr f3 problem
Check your battery fuse.
Old Jul 9, 2011 | 09:51 AM
sdots24's Avatar
I checked the main fuse 30a and that one is fine.
Checking on the 15a now... where is that located though?
Old Jul 10, 2011 | 08:26 AM
slomofo's Avatar
GDD Member
I don't know where it is, I've never owned a CBR. Most fuses and stuff are in the tail section of sport bikes, so I'd poke my head in that area.
Old Dec 16, 2011 | 09:41 AM
Nelson1407's Avatar
Did you know there are two 30A fuses? One's horizontal but that's not your main fuse. The main fuse is in the same plastic (rubber) structure but a little bit further back on the topside. Just behind the plastic connector you see. You might have to dismount the gastank.
Nelson
seamus657
Mar 6, 2009 08:47 PM
Tip14
Dec 27, 2007 01:13 PM
rhd_ef8
12
Apr 29, 2007 11:27 AM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
rasta420
Nov 6, 2002 08:41 PM
