new 11in brake upgrade problem
okay so i put everything together and when i turn the rotor it wables i was told by my cussin that i didnt instal the hub on right and try to tightin the axel nut so i did and no help has this happend to ne1 and no the rotors are not warp or nething HELP PLEASE!!!!!!!!!!
http://www.youtube.com/watch?v=BwJ0GIUgeDs
no i had it up on the lift no tires on and i spun it by hand and everything cleared i only have this problem on the right side it like wobbles at a certain point when i turn it
okay so i changed the wheel bearings and its still does it the noise is like metal scraping very annoying sound i put the car on the lift and had my budy sit in the car and turn the wheels and the noise isnt there but when i put the car down and drive its there please help!!!!!!!!!!!!!!!!!!
what do you mean buy the hub rings as in the snapp ring that you have to take out in order to take the wheel bearing out? if that what your talking about yes but i putt it back on
butt one thing i didnt put back on becouse they broke was the seal that i wastold wasonly used to keep the grease in butt that shouldnt be the problem or should it
i just found this video and mines does the same exact thing
check for caliper clearance. if you drove it and the caliper is hitting then there should be scratches on the inside of the wheel. I had that problem when I got the miata daisies. 5mm spacers fixed it right up.
Ratchback
Feb 22, 2005 05:37 PM
