Transmission & Drivetrain Gearboxes, Differentials, Clutches
B-Series Hydro case + LSD question
Old Jul 8, 2011 | 12:20 PM
SL0WEGG's Avatar
Default B-Series Hydro case + LSD question
Are all b series hydro transmission cases interchangeable? My case is semi busted and was wondering If I could use an S80 case with my y21 gears and differential?
LSD question:
Are the CTR and y21 optional LSD the same? If so, I would assume I could use the ctr lsd with my y21 gearing since they share the same final drive.
Or can you tell me whether or not my case is okay. It appears those pieces that broke don't support anything but I think it might channel fluid. But then again i'm not sure. Any help would be appreciated
meth mouthed the stock non lsd diff
Old Jul 8, 2011 | 01:16 PM
Gearspeed-Performance's Avatar
Default Re: B-Series Hydro case + LSD question
Yes all Hydro B-Series cases are interchangeable. The CTR will be a Gear-type LSD, same as the ITR and the factory LSD diffs found in the Y21 are a Viscous type. The ring gears have different bolt patterns. If you are gonna use the CTR Diff..you will need a matching countershaft and ring gear.
Those fins are used to channel fluid to lubricate the differential...If you have another case..I would use it.
Old Jul 8, 2011 | 04:11 PM
SL0WEGG's Avatar
I've got a case in mind that someone is selling
As far as the LSD goes, It seems as though after a little bit of research that I definitely don't want a viscous type LSD for drag racing. Is there any type of OEM gear type diff that would drop in without having to find a countershaft for it. I'm thinking it would be a bitch and a half to find a ctr countershaft. But I see that I could use 94+gsr/itr and 99-00 si ring gear and counter shaft? I think at that point it would be kinda pointless and I might as well get an mfactory helical diff. Before I get ***** deep and order the wrong ****. Is MF-TRS-05B16 what I need? Thanks for your help James.
edit: Since the CTR diff already has a ring gear on it. If I got a 94+gsr/itr or 99-00 si countershaft, this could work with my y21 gears?
Old Jul 8, 2011 | 09:23 PM
I have a case as well
The Viscous LSD tends to break at the neck internally..I have a broken one from a customer on the bench right now. If you go with an M-Factory or Quaife unit...you cant go wrong. I also like the Wavetracs as well.
The GSR/TypeR have a different inner diameter ring gear vs. the 99 Si(B16 hydro trans) I usually like to use matched ring and pinions. Your gears will fit the countershaft in either set.
I have a case, ring and pinion, and an M-Factory LSD in stock. I got everything you need
Pm'd you some prices
400hpcrx
Aug 18, 2014 04:40 PM
Wh0 Iz UNREAL07
Nov 11, 2010 09:42 AM
boostylicious
Nov 7, 2004 04:12 PM
compwc18
Aug 11, 2004 07:16 PM
