B20 with b16 head or just go b16 engine
Old Jul 8, 2011 | 03:09 AM
sts555's Avatar
Default B20 with b16 head or just go b16 engine
Hey i am trying to decide whether to swap a b20 with b16 head into my 89 honda crx, but people are telling me that i can get more power out of just a b16 engine
Old Jul 8, 2011 | 03:33 AM
turbodcxbro's Avatar
Default Re: B20 with b16 head or just go b16 engine
A B20 with a B16 head (done properly) will crush a stock B16 hands down. Maybe if you build the hell outta the B16 and spin it to the moon you'll make more power but thats about the only way..
Old Jul 8, 2011 | 03:53 AM
AlHimself's Avatar
http://www.youtube.com/watch?v=9ordbcQAjNc
this was my stock 20 bottom end and b16b head,
i would love to see a b16a do this to a tuned s2k
Old Jul 8, 2011 | 04:02 AM
N/A's Avatar
N/A
Purpose Built
Lol. I used b16 blocks to make a coffee table
Old Jul 8, 2011 | 04:14 AM
speedy666's Avatar
b16 with a racing skunk camshaft.maybe a stage three clutch and youll be rippin.
just a 16 or a 20?????????it'll be good on gas
Old Jul 8, 2011 | 04:19 AM
AlHimself's Avatar
i wouldnt run anythin over a typeR cam on stock valve reliefs, maybe buddyclub spec3+
Old Jul 8, 2011 | 07:45 AM
Red_Army's Avatar
you kept up with a s2k? good job. beating it would be worth talking about.
a b20 block with b16 head would kill a b16a all day. unless you bored it out in which you'd just have a 1.9.
Old Jul 8, 2011 | 09:47 AM
sowellman88011's Avatar
Actually a b16 bored to b20s 84mm only equals a 1.7 because of stroke.
the b20 should rip a b16 all day with similar money in them. the only thing a b16 is better for is rpms or if youre trying to stay within a specific lower power, like me. im building a b16 for my local time attack where we class by power to weight ratio. also the track has half the track that being able to stay in gear and pull higher rpms means no time lost shifting, where with a b20 id have to shift up then 1-2secs later shift back down.
Old Jul 8, 2011 | 09:57 AM
$hawNPeeZyy's Avatar
The only way the B16 would make more power is if it was turboed, and the B20/V was naturally aspirated. If you wanna stay naturally aspirated, the B20 block B16 head combo would be the way to go.
Old Jul 8, 2011 | 10:34 AM
sts555's Avatar
THanks guys , i heard that alot of b20 with b16 head have failures, but i know itscheaper then buyng a b16
Old Jul 8, 2011 | 11:01 AM
sts555's Avatar
oh and what tranny should i get for b20 with b16 head
AlHimself's Avatar
what video were you looking at? O_o
clearly past it at the end
s2k was in first gear btw :D
Old Jul 8, 2011 | 11:05 AM
AlHimself's Avatar
if your staying stock i recommend changing rod bolts to arps..
i had a 98spec itr box with a KAAZ 1.5way was serious, also an itr flywheel is a good upgrade.
although i dunno how freely available those parts are to you guys in the US
Old Jul 9, 2011 | 08:32 AM
Red_Army's Avatar
the b16 tranny. with an ls final drive and maybe 5th. LSD.
Old Jul 12, 2011 | 06:12 AM
AirborneINF's Avatar
For NA, I'm running a GSR tranny.. Best of both worlds, unless your budget can call for an ITR or CTR...
Old Jul 12, 2011 | 01:27 PM
soupE__'s Avatar
Is that the lower compression b20 or higher one in that video against the s2000?
RadekSkylark
Jul 19, 2010 06:15 AM
madmoto154
Dec 11, 2008 09:08 AM
TwoToes
Mar 18, 2008 06:20 AM
dtown_racer
Feb 23, 2005 02:44 PM
