Power Door Locks 92 S' swapped with 95 Si Doors
i did a search i couldn't really find anything specifically of what i'm asking it seems like there was more difficulty then what i think it should be. I have a 92 S that didn't come with power locks. I found a 95 Prelude Si with power locks at a Junkyard i swapped both doors...my question is how can i get the the power locks to work? shouldn't it just simply being able to get power to them? Maybe ima dummy put wiring hasn't been my strong suit lol. appreciate any help.
You're supposed to have the dash harness too. If you want just the driver's side to work with what you have now, you have to supply power to the white wire going into the door lock control module (under hood fusebox has a spot for it if you want to be precise about it). If you want both sides to work, you have to supply power, and run about 6 wires from the driver's door to the passenger's door. The manual has the diagram showing which wires. I think i have a good picture I made on my home computer too. I'll upload it if I can find it after work.
Yea.. I just went through all this in case you couldn't tell.
Yeah if you could upload that diagram would be most appreciated cause i don't have the original manual. :/ and definitely appreciate the help. i've had the doors on there for awhile i've just been lazy and manually locking them. but now i'm like if i have power locks i might as well use them haha.
Sorry, had to go out of town and this slipped my mind. Looks like it's just 4 wires, then the ignition switch one which I believe is for having them lock automatically when you start the car. Someone please correct me if I'm wrong.
It's cool man appreciate you still being able to post it. Wow! Huge help...thanks bro i should be able to get this done this weekend. Otherwise i'd been lost lol.
